Old 03-05-10, 05:28 PM   #1
paiste
Default Rattle can spraying advice needed!
Ok, so I am certainly going about this @rse about face as I have already done most of the spraying but here goes!
I am after a bit of advice of how to get an acceptable level of finish spraying my belly pan with a rattle can.
I prepped the fairing and applied a coulpe of coats of white plastic primer.
wet sanded it with 1000 grit, applied three light coats of colour (canyon yellow) wet sanded with 1000 grit.
I have since applied about 4 coats of clear coat. Should I be wet sanding in between coats or hust after the last coat?
Is 4 or 5 coats of clear coat too much too little?
Also how long should I leave it before giving it a final wt sand and compound/polish?
I am using my greenhouse as a spray booth come low bake oven!!
I am using holts colour matched paint and Halfrauds clear coat. I know these aren't the best quality, but then neither is my belly pan nor my spraying technique! I am just hoping for a half decent result that will look ok when riding along or whilst squinting
Thanks all
Old 03-05-10, 06:08 PM   #2
Default Re: Rattle can spraying advice needed!
http://www.bayarearidersforum.com/fo...d.php?t=264901
need advice on spraying kiggles Bikes - Talk & Issues 4 14-03-10 09:21 AM
Help Needed, Spraying gralln9 SV Talk, Tuning & Tweaking 0 19-04-09 06:20 AM
Advice on Exhaust Rattle Please VolatileParsley SV Talk, Tuning & Tweaking 4 27-08-08 12:07 PM
Advice Needed Please????? SAMMY650 SV Talk, Tuning & Tweaking 15 03-03-08 09:10 PM
Advice needed 650newb Exhausts 4 06-12-04 10:40 AM
