Old 09-05-10, 09:22 AM   #1
Geodude
Geodude's Avatar
Default Removing/replacing subframe.
Im about to replace the rusted mess of a subframe on my 99 sv650 naked with a decent one and just wondered if anyone has done this before and were there any problems i should look out for?
Old 09-05-10, 09:26 AM   #2
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: Subframe swap
I did it with no problems although I would suggest that you get the replacement powdercoated before fitting as it'll last much longer and shouldn't cost to much. The other thing I did was took some pictures of where the wiring went etc so it would go back the same
2011 Speed Triple 1050
Old 09-05-10, 09:27 AM   #3
dirtydog
Knob faced knobster
dirtydog's Avatar
oh and i also replaced the normal bolts etc with stainless steel ones
Old 09-05-10, 09:28 AM   #4
mjc
IIRC its pretty straightforward, just make sure you remember the routing for all the wiring, brake hose etc. Might help to take a photo once youve removed the plastics.
Old 09-05-10, 09:28 AM   #5
mjc
why do i type so slow? lol. I also went powder coat + stainess fasteners. I kept the standard M10 subframe bolts tho, didnt fancy changing them for a different material.
Old 09-05-10, 09:31 AM   #6
If you do replace those M10, measure pitch. They are fine thread, not standard coarse thread.
Old 09-05-10, 09:36 AM   #7
Geodude
Geodude's Avatar
Cheers for swift replies, you guys are great
Old 09-05-10, 09:37 AM   #8
dirtydog
Knob faced knobster
dirtydog's Avatar
I left those ones as standard, wasn't sure if they werehigh tensile or something. Didn't want the subframe falling off with my fat **** on it!
Old 09-05-10, 03:15 PM   #9
shelleyamy
Default Re: Removing/replacing subframe.
Just had mine powder coated, and i am not sure if it's the coating process, or some rough handling, but it didn't line up when it came to refitting, but just fit 2 of the 4 bolts, and it's easy to twist back into shape. Same would apply if you have a slightly bent one.
Oh and you will need to tap out and clean the threads up, even if they used bungs.
Mike
Old 09-05-10, 03:33 PM   #10
sprocket
I didn't go the powder coating route but used some black hammerite on my sub-frames . . seems to do the trick But pretty straightforward process taking them off
Removing Engine/Replacing Gearbox Essex-Tacy SV Talk, Tuning & Tweaking 29 22-02-10 07:01 PM
Curvy faired subframe - does naked subframe fit? Geodude SV Talk, Tuning & Tweaking 7 13-02-10 05:39 PM
Replacing the Daytona. the_lone_wolf Bikes - Talk & Issues 35 23-05-09 01:14 PM
Replacing stuff...... lily Idle Banter 16 11-08-08 07:54 AM
Replacing the radiator - big job or little job? Durbs SV Talk, Tuning & Tweaking 26 06-01-08 09:54 AM
