Old 12-05-10, 05:56 PM   #1
GreyFear
Default Clutch Problems?!
This has happened twice in the last week now, but through general slipping *cough* abuse of my clutch it gets really tight and locks itself in "slip" so to speak, and i end up riding home on a twist and go bouncing off the rev limiter everytime i try to accelerate.
The only way ive found to solve this is to undo the clutch cover, slacken everything off at the bottom end and re-tighten the lot, ive had my SV for 8 months now and no problems like this until last weekend..
Any ideas on the bigger picture??
Thanks in advance
James
Old 12-05-10, 06:02 PM   #2
Biker Biggles
Biker Biggles's Avatar
Default Re: Clutch Problems?!
Have you adjusted it properly as per the manual?If not thats where Id start.
Old 12-05-10, 06:07 PM   #3
GreyFear
Done it all by the haynes manual
Old 12-05-10, 06:09 PM   #4
try testing the clutch doing about 40mph, knocking it into top gear upping the revs to about 6500 and letting the clutch out fully.
If the revs stay high the clutch is slipping
Old 12-05-10, 06:12 PM   #5
mjc
If clutch lifter is adjusted correctly and clutch is still slipping, most likely problem is friction plate wear or spring wear. crack open the clutch and measure both against the service limits in the manual.
Old 12-05-10, 06:14 PM   #6
Jayneflakes
Jayneflakes's Avatar
When my Worm Gear Jammed, my clutch was slipping so badly, I thought the plates had gone. Turned out to be crud in the worm, preventing it from working properly.
If the plates are shot, it should be fairly simple to replace I imagine, although I think you may have to do some major stripping of bits to get to there to start.
Jayne you're a Pussy Magnet
Old 12-05-10, 06:21 PM   #7
GreyFear
mjc i need to wait until the 28th when i get paid before i can even think about cracking open the clutch to take a deeper look unfortunately, and nice DP ^^
Jayne i presume by the "worm" you mean the mechanism at the bottom end of the clutch cable, i cleaned it all up when i had to adjust it the first time.
The first time it went i was having a tear around with my mate involving alot of heavy clutch slipping, and the second time the same situation, its ok in general bimbling around but i love opening her up
Old 12-05-10, 06:23 PM   #8
mjc
good point, didnt think of that
yeah its pretty easy. If you have a haynes manual dont try making that clutch holder tool they suggest, just stick it in 1st and hold the back brake on.
Old 12-05-10, 06:46 PM   #9
GreyFear
i had to help a fellow sv over change his clutch plates a few weeks ago, so ive got a rough idea on changing them.
i think i'll have to put up with bimblin around until i can afford to open her up and take a serious look and see if bits need replacing
Clutch problems. otacon88 SV Talk, Tuning & Tweaking 13 16-05-09 06:19 AM
Clutch problems. chakraist SV Talk, Tuning & Tweaking 13 03-02-08 06:03 PM
Clutch problems from new dmracing SV Talk, Tuning & Tweaking 3 03-08-06 01:00 PM
Clutch problems? PWNDLOL SV Talk, Tuning & Tweaking 1 05-07-06 07:10 AM
clutch problems... SVNez SV Talk, Tuning & Tweaking 12 14-05-06 10:07 PM
