| SV Talk, Tuning & Tweaking Discussion and chat on all topics and technical stuff related to the SV650 and SV1000 Need Help: Try Searching before posting |
I've been searching the forum for info on the valve clearance service and couldn't find general info about what to expect to pay for this service.
I'm looking for a garage in the Cheshire area and have had a quote from my local Suzuki dealer who have serviced my bike in the past. I was quoted £337.15 for the major service including valve clearance check (15k service). I looked in the manual and it's a fairly comprehensive service including plug change (four on mine), filter, F.I. check etc. Has anyone had this service done local to me and what sort of price did you pay...? Also, does anyone know whether the quoted price would include actualy changing the shims if necessary? The bike is a 650s K7 (twin plug head), Thanks Dave
1989 - 2010: Yamaha DT50-Suzuki X1-Honda CB100n Yamaha RD125 LC-Yamaha TZR125-Yamaha DT125R Yamaha RD350 LC-Suzuki RGV250 M-Honda VFR400 NC30 Yamaha YZ-250-Yamaha RD350 FII-Suzuki RGV250 R Suzuki SV650 K7... |
FFS do it yourself
Checking the valve clearance is not difficult, and only mildly to change the shims if the check shows a change needed. It sounds like the garage is charging you to change them, not check them.
Not Grumpy, opinionated. |
I'm getting a BIG service done next week by Spannerman.
that's valve clearances, the whole lot etc. And it's going to be about 6 hours labour i believe + parts, etc So it costs a bit, but that's because there's a lot to do! Way I see it is that I want my bike to last so don't want anything that's silly that could have easily been checked / fixed causing my engine to implode! ![]() Play it safe! |
It is if you arent mechanically minded. Its a bit like an IT expert telling me to fix my own IT system as he thinks its easy!. Ive seen too many messed up home services lately due to people being advised its easy!. Two snapped spark plugs, one cracked sump and 3 stripped sump threads since Feb!!
www.stevejordanmotorcycles.co.uk Minitwin championship winners 4th year in a row!!. Yay! |
TBH I'm pretty mechanically compitent, that's not the issue for me - time is the issue as I have a busy job and young family so I can justify spending a bit of cash to save me spending all day in the garage.
Of course, with something like this the garage has done it many times before so has the right tools to hand and is prepared for anything that could go wrong. I was just posting to see if anyone could recomend any other garages in my area... I have spoke to the garage who quoted me after posting this and they said that any re-shimming is included in the cost. D
#6 | |
Pointy K3S in SuperSonicSilver, R&G bungs, Carbon Can Co slip-on SOLD TO MEMBER "Cobra"! So long old friend! I'm going all Charley Boorman on yo' ass. Can't filter or indicate any more. |
If your bike is out of warranty Id do it myself.Checking the valves is easy and they dont often seem to need adjusting(which is rather more difficult and time consuming).
If you find them to be out then it might be worth getting an expert to do it.
Hiccup Boy
i take it you earn whatever the garage charges an hour then?
Change the plugs and oil yourself at least. It's only a mornings work tops.
SV650sk6 - My bike doesn't like dealer servicing. It loves a personal touch and only like to be touched by foreign hands for tyres. Hovis, the man and now the Legend! |
#9 |
Five hours labour circa 35-60 p/h depending where you are plus approx 80-100 in bits. Inc balance throttle bodies, ads clear down, coolant, brake fluid check change etc. Poss mileage also if 2 years old fork oil should be changed. Trust me it's comes out like gravy at that mileage!
Waiting for coxxy to be brave enough to turn up and see me |
#10 |
To just check the valve clearances should only take about an hour or two. The hardest part is probably removing the front plug and cover without taking the radiator off the bike. Changing shims is more involved...but by checking them yourself you could avoid the need to put it in a garage altogether if they're in spec.
| Thread Tools | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Valve clearance, should I take it? | Old Git | SV Talk, Tuning & Tweaking | 21 | 14-09-09 11:54 AM |
| Valve clearance checking. | Mark_h | SV Talk, Tuning & Tweaking | 6 | 22-12-08 07:31 AM |
| Valve Clearance Tight | stnd | SV Talk, Tuning & Tweaking | 2 | 02-09-08 10:52 PM |
| 15k service - valve clearance | The Mass | SV Talk, Tuning & Tweaking | 21 | 18-08-05 09:41 AM |
| Valve Clearance | Craig | SV Talk, Tuning & Tweaking | 3 | 14-02-05 06:34 PM |
