Old 14-05-10, 01:35 PM   #1
barwel1992
Default a2 stainless vs 8.8 steel, brake calliper fasteners
well i purchased some a2 stainless steel fasteners last night for my brake calipers but since then thought about it a bit more and it turns out that a2 does not have as much tensile strength as the 8.8 steel bolts, the problem is i just cant find any m10 x 35 1.25 pitch zink plated 8.8 bolts (socket cap or flanged nex preferd)
my question is will the a2 stainless ones be ok? or should i at least get a4 stainless bolts ?
(pro bolt dont state what stainless they use, only the grade titanium they use on there titanium bolts (grade 5))
Old 14-05-10, 01:55 PM   #2
Default Re: a2 stainless vs 8.8 steel, brake calliper fasteners
I doubt Pro Bolt aren't going to sell bolts that ain't up to the job, otherwise they'd not sell any
Ring them up an specify they're for calipers
I aint had any issues with my Pro Bolt caliper bolts.
Old 14-05-10, 01:58 PM   #3
barwel1992
^ will do, the bolts im looking for are under calliper mount bolts for the rsv mille 98-02 so they are defiantly for callipers it just dose not state what grade
Edit: its 316 grade so A4, looks like i need to get some as the one i got were a2
Old 14-05-10, 02:01 PM   #4
A2 M10 are gonna be way stronger than you need imo, suzuki make theirs of cheese and they seem to do an ok job.
Old 14-05-10, 02:02 PM   #5
The answers on the tin
Old 14-05-10, 02:02 PM   #6
They'll be fine
Old 14-05-10, 02:15 PM   #7
barwel1992
so just stick with the ones i got ? (just as im about to click the pay now button lol)
Old 14-05-10, 02:16 PM   #8
timwilky
timwilky's Avatar
Well if you want steel flanged bolts m10*1.25*35 with a coating a search found these. Cannot say anything about them, simply a google result
Not Grumpy, opinionated.
Old 14-05-10, 02:18 PM   #9
barwel1992
it doesn't say what they are made of, thanks though just says chrome
Old 14-05-10, 04:09 PM   #10
philbut
I personally would not use stainless bolts to mount my calipers. I use zinc coated hardened steel. My bolts are now a bit furry - but better than than one shearing. Go for titanium if you want them to look good, stainless should not be used in safety critical applications.
Chrome coating a bolt will reduce the properties of the original steel, which is why chromed caliper bolts are usually a larger size than you really need. Still better off going with a coated bolt rather than stainless though.
Stainless steel rod dirtydog Bikes - Talk & Issues 15 15-02-09 12:52 AM
Stainless steel Brake lines for a Pointy neio79 For Sale - SV's and SV related items 2 30-01-08 08:44 PM
installing stainless steel braided brake lines cmit37 Bikes - Talk & Issues 11 06-06-07 08:18 PM
Stainless fasteners Tiger 55 SV Talk, Tuning & Tweaking 10 13-04-07 08:31 PM
To stainless steel or not to stainless steel...... svrash SV Talk, Tuning & Tweaking 39 21-04-06 09:04 AM
