Old 15-05-10, 12:11 PM   #1
barwel1992
Default K3 sv650 front end bit's
sticking this up now just to get the ball rolling These Items will be officially FOR SALE OF LATE NEXT WEEK OR EARLY FOLLOWING WEEK but you can have first dibs now
SV650 K3 Parts
the things i have are
Front wheel, straight good condition, silver, new bearings and seal's late last year (they have 2000 miles about) comes with spare dust seal does not include disks/bolt,axle,tire,speedo sensor £70 + £15 postage
Front Calliper's (pair) Good seals recent serviced, (will clean a grease them up again) including slide bracket thing, Sinterd HH Pads only about 800 miles on them, including bleed nipple (not including banjo bolt) not including mount bolts £60 + £10 postage
SS Front Brake Lines These are for a Naked bike, they are slightly longer to take accommodate for renthal bars they are cobra (rebranded hel) race lines (2 lines) and are less than 3 months old, good condition, will include the calliper banjo bolts, and a fine thread dobble bolt for the master cylinder side (might not fit your MC as some are different thread pitch) SOLD (£25inc P&P badger)
Front Fork Legs, slightly bent, needs new slider tubes, stock springs, will need new oil (will be emptied) and fork sliders and one of the fork shields has been broken, overall good condition slight flaking and scuff on the bottom of the right side leg, will include pinch bolt and preload adjusters £30+ £15 postage
Fork Springs .9kg/nm K-tech fork springs these were used for a week (i kid you not) i will also include the correct spacer i pay'd £80 ill take SOLD (£60 Inc postage Speedy)
Front axle, usual used condition £5 + £5 postage
Brake disks 4.5mm thick aprox, no rattle SOLD (£30 inc P&P flymo)
I need to check the forks and K-tech fork spring over and double check every thing else, to make sure it is as described
I will be able to do combined postage on multiple thing things (will be using a courier, and one large package is cheaper than multiple small items)
PS IN the next week item detail may change
Pictures will Be added Tomorrow or Wednesday
Thanks For looking
In light of another thread on hear about items not been sent hear is my ebay feedback page
Old 15-05-10, 02:50 PM   #2
xXBADGERXx
Default Re: K3 sv650 front end bit's
How long are the lines Barwell , I am slinging some SV1000 brakes on my bike and could do with slightly longer lines .
Old 15-05-10, 05:02 PM   #3
Speedy
PM'd!!!
Old 15-05-10, 07:36 PM   #4
pojic
If the brake lines are plain silver in colour and still available, I'll take them.
Cheers,
pojic
Old 15-05-10, 07:48 PM   #5
barwel1992
all PM's replied
and will measure the line for you badger, pojic they are plain silver , if badger doesn't want them they you can have them
Old 16-05-10, 04:30 PM   #6
BomBalong
and if they dont take the brake lines barwel can i has?
Old 16-05-10, 11:48 PM   #7
barwel1992
^ indeed you can
right pics and more info now
disk's these have no rattles, and are about 4.5mm thick
wheel
Brake lines, these do not come with crush washers and the MC banjo may not fit(some are diff) lenghts are 86cm (middle to middle of banjo holes) and 87.5cm for the left hand (longer) line not exact measurements as they were a pain to measure
calipers, cleaned and greased load of pad left
Axle
Old 17-05-10, 06:14 PM   #8
barwel1992
bump any one elses intrested in any of this
Old 17-05-10, 06:50 PM   #9
xXBADGERXx
The lines are 10cm longer than my current ones so they sound ideal for what I need , I measured mine with string from centre to centre and they are shorter than yours so I will take them sir , consider them now sold along with that other item we discussed in PM
Old 17-05-10, 06:52 PM   #10
barwel1992
PM heading your way
SV650 Front Wheel - Do any other Suzuki models use the same front wheel? williamturner1 SV Talk, Tuning & Tweaking 11 30-05-10 02:31 PM
Bit's n bob's inc chain, srockets and bronze undertray chunkytfg For Sale - Other Bikes and General biking items 5 25-03-09 11:18 AM
Bit's i still got left svrash For Sale - SV's and SV related items 15 04-08-08 09:38 PM
Front Discs (pair) for sv650 '99 curvy + Front wheel mikeSV Stuff Wanted 1 28-05-08 04:21 PM
Anything from an '04 SV650/S front-end tekjunkie Stuff Wanted 2 17-04-07 10:27 PM
