Old 16-05-10, 05:17 PM   #1
adam_castell
Default breaking SV650S curvey 2001 pearl lively yellow
breaking an SV650S curvey 2001 in pearl lively yellow 20,000 miles on bike
the bike was dropped recently, damaged to screen, rh upper, lower fairings, brake pedal, exhaust can, rh footpeg, and rh indicators. everything else is in good nick
all the stuff availible is listed below, nothing else is avalible apart from bolts and screws (although i may have forgotten to list some bits)
collection is welcome and is from dunstable
contact me via PM for bulk discounts,
i will remove items from the list when i have recieved payment.
payment by cheque, cash, paypal, or bank transfer
although i will take payment via PAYPAL, but please slecet to cover the fees yourself
adam_castell@hotmail.com
please write down which items you have brought when sending payment and you postal address if applicable.
i will not hold and wait for payment for longer than a couple of days
items in red are reserved and awaiting payment
i will post items on saturdays, and only items paid for by the end of thursday will be packed ready for me to post on saturday.
http://img.photobucket.com/albums/v7...DSC00137-1.jpg
http://img.photobucket.com/albums/v7...l/DSC00151.jpg
http://img.photobucket.com/albums/v7...l/DSC00152.jpg
http://img.photobucket.com/albums/v7...l/DSC00153.jpg
http://img.photobucket.com/albums/v7...l/DSC00154.jpg
http://img.photobucket.com/albums/v7...DSC00155-1.jpg
http://img.photobucket.com/albums/v7...l/DSC00156.jpg
http://img.photobucket.com/albums/v7...l/DSC00157.jpg
http://img.photobucket.com/albums/v7...l/DSC00164.jpg
DESCRIPTION ---- PRICE + P&P
airbox £10.00 £5.00
axle front £5.00 £3.00
axle rear, axle nut, and washers £5.00 £3.00
bar end weight £2.50 £2.50
brake callipers front£40.00£10.00
brake disk rear£10.00£4.00
brake light assembly£15.00£4.00
brake master cylinder front & reservoir£15.00£3.00
brake master cylinder rear & reservoir£10.00£3.00
brake switch rear and spring£5.00£3.00
brake torque arm£5.00£3.00
clip-on LH£10.00£3.00
clip-on RH£10.00£3.00
clock surround£20.00£4.00
clocks (with 20,000 miles on the clock)£40.00£5.00
clutch cable£5.00£2.50
clutch lever£10.00£3.00
coolant reservoir £5.00£3.00
exhaust headers set standard£30.00£15.00
fairing bracket LH upper£2.00£2.00
fairing tail piece£10.00£3.00
fairing upper RH (scuffed and cracked)£5.00£6.00
fan£15.00£5.00
fork springs standard, from bike with 16k miles£10.00£5.00
forks, hagon progressive springs fitted, rebuild and new oil at 16K (has normal corrosion on fork legs)£100.00£20.00
frame, swingarm, and linkage 2001 private plate KAZ 9931, V5, number plate included£120.00£40.00
gear pedal£30.00£4.00
grab rail£10.00£4.00
haynes manual curvy version only£10.00£2.50
headlights£40.00£6.00
heel plate LH (some marks)£5.00£2.50
heel plate RH (some marks)£5.00£2.50
horn£5.00£3.00
ignition coil F£5.00£3.00
ignition coil R£5.00£3.00
indicator rear LH (brand new)£20.00£3.00
indicator rear LH (slight scuff)£2.00£3.00
indicator rear RH (slight scuff)£2.00£3.00
lock set (3 x locks and 2 x keys)£50.00£5.00
mirror infill panel LH£3.00£2.00
mirror infill panel RH£3.00£2.00
mirror LH (few marks)£20.00£5.00
mirror mount spacers pair£5.00£2.50
mirror nuts£5.00£2.00
mirror RH (few marks)£20.00£5.00
mud guard£20.00£5.00
mud guard mounting brackets and bolts£5.00£3.00
number plate light£5.00£3.00
parking / side light£5.00£3.00
pillion / exhuast hanger RH£15.00£3.00
pillion foot peg LH£5.00£3.00
pillion hanger LH£15.00£3.00
radiator temp sensor£5.00£3.00
riders foot peg hanger RH£7.00£3.00
riders foot peg hanger LH£7.00£3.00
riders foot peg sensor bolts (3 avalble price each)£1.00£1.00
seat catch mechanism£5.00£3.00
seat rear£25.00£5.00
side infill panel LH£5.00£2.50
side infill panel RH£5.00£2.50
starter motor relay£10.00£3.00
steering stem nut£5.00£2.00
subframe front£20.00£10.00
subframe rear£30.00£20.00
switch gear LH£10.00£3.00
tail tidy suzuki oem (damaged, but repairable)£10.00£10.00
throttle cables£5.00£3.00
undertray standard£15.00£8.00
vacuum fuel pump£15.00£3.00
vacuum fuel valve£10.00£3.00
wiring loom£25.00£5.00
yoke bottom, stem, bearings£15.00£5.00
Old 16-05-10, 05:31 PM   #2
Default Re: breaking SV650S curvey 2001 pearl lively yellow
Are the mirror mount spacers to extend the mirrors out to give a better view. If so I'll have them
Old 16-05-10, 05:32 PM   #3
husky03
i'll take front brake discs mate-can you send me a pic before i send payment though.
Old 16-05-10, 05:34 PM   #4
2000curvy
PM'ed you for the mudguard and left hand footpeg
2000curvy is offline   Reply With Quote
Old 16-05-10, 05:38 PM   #5
2000curvy
Also the throttle tube if possible
Old 16-05-10, 06:42 PM   #6
adam_castell
no, just for normal fitment
have put a few pics at the top of this thread, i can measure the thickness tomorrow if you like
the speedo cable has rubbed a little of the paint away, but not noticable when speedo cable is in place, also forgot to mention, it has a pyramid fenda extenda fitted to the mud guard. LH footpeg is fine, and ok for throttle tube
Old 16-05-10, 07:16 PM   #7
2000curvy
Dibs on the hugger as well please
Old 16-05-10, 08:12 PM   #8
leebex
i`ll have both the fairing lowers if still available please.
Old 16-05-10, 08:17 PM   #9
adam_castell
Old 16-05-10, 10:51 PM   #10
Ceebl
Why is the battery in RED writting? I'm assuming it works and is on trickle jus to keep it maintained?
Curvy 2001 SV650S Fuel Tank in Pearl Canyon Yellow (Y9F) + in March > bike trickster For Sale - SV's and SV related items 4 24-02-10 09:35 AM
Touch-up paint pearl lively yellow Old Git Stuff Wanted 7 09-05-09 12:51 PM
bits for curvy k2 pearl lively yellow 2002 cymroboi Stuff Wanted 2 16-02-09 05:09 PM
Wanted, Pearl Lively Yellow (Y9H) petrol tank northwind Stuff Wanted 0 26-05-08 12:50 AM
2 cans of pearl lively yellow Y9H paint adam_castell For Sale - SV's and SV related items 4 27-11-07 03:11 PM
