Old 23-05-10, 06:38 PM   #1
Question Calling all trumpet sprint owners
Hi Guys...
I have a few questions.
Do you have sat navs? what mounts do you use? i have tom tom 710.
Tank protectors? which ones do you use?, need something for sides and crotch part
Rear hub nut cover, anyone got one, where from?
Taller screen, have you fitted one?
Whats the best rack mount for a givi top box? i have box and plate.
Thanks
Phil
Old 23-05-10, 07:04 PM   #2
Dicky Ticker
Default Re: Calling all trumpet sprint owners
Telforizer
Clear plastic car paintwork protector cut in to shape[Cheap solution]
Watch E-bay[They come up now and then]
Tall screen very protective but stops the rain clearing from your visor and creates helmet wind noise
Triumphs own rack
Unfortunately I have the older 955i otherwise you could have tried all these bits before buying.
Old 23-05-10, 07:18 PM   #3
mattSV
mattSV's Avatar
SatNav - I have a telferizer - click here for a write up and pictures
Tank protector - have got the triumph carbon tank protector, however still need to get something for the sides
Tall screen - the newer (2008 onwards I think) have a higher screen than the older ones, haven't bothered changing mine
Rack - I have the triumph rack with a givi adapter plate, and an E46 box
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 23-05-10, 08:18 PM   #4
Gazza77
Gazza77's Avatar
SatNav - I have a Zumo 550 and use the mount it came with. Works fine for me.
Tank protector - Triumph Carbob one, was on the bike when I bought it.
Tall screen - I have the Triumph taller screen, which was fitted as standard to later bikes. Is better than the lower one for me.
Rack and hub cover, no idea.
Formerly Blue K5 with added bits
Then Triumph Sprint ST with scottoiler and R&Gs & TOR exhaust
Now Benelli Tornado
Gazza77 is offline   Reply With Quote
Old 23-05-10, 08:34 PM   #5
Am i right in assuming i have the taller screen?
Been looking at http://cgi.ebay.co.uk/MRA-TRIUMPH-SP...item19ba602df5
Thanks for input guys.
Old 23-05-10, 09:26 PM   #6
Essex of Essex
Smile Re: Calling all trumpet sprint owners
Zummo 550 on a RAM mount from Telferizer it replaces one of the Allen bolts in the bars, don't like tank pads so run with a baglux tank cover. The hub cover came from Triumph. Mine is a late model machine with the taller screen as standard this works well for me 180 cm tall.
Old 24-05-10, 09:33 AM   #7
Reckless Rat
Tank protection: Std Triumph cf. Does what it says on the can
Wheel nut covers: Expensive from Triumph dealers, should have been fitted as standard! Other versions available from ebay etc, not cheaper though.
Take a look on
http://www.bikersoracle.com/triumphs...orum/index.php
For a more UK based triumph forum.
Old 30-05-10, 11:16 AM   #8
Does anyone know the part number for the sprint top box rack mount?
Really need to get this sorted as i have a 46l top box sitting there doing nothing .
Calling Dan and other Hornet owners Mark_h Thames Valley 5 14-05-09 10:29 PM
Calling Naked Owners... MR UKI (1) SV Talk, Tuning & Tweaking 6 23-06-08 12:10 PM
Calling Scorpion Can Owners?? Rich Exhausts 10 28-03-07 09:24 PM
Calling pointy owners BILLY SV Talk, Tuning & Tweaking 6 09-06-06 07:24 PM
calling k2 and k3 owners curium SV Talk, Tuning & Tweaking 12 11-12-04 11:52 AM
