Old 25-05-10, 11:40 AM   #1
hardhat_harry
Default Factory Pro Carb kit
Is there anything special about the factory pro needle and jet kits. On my old CBR600 the dynojet kit had needle shrouds for better atomisation do the factory kits come with something like this?
My bike is going to the dyno to get setup with the mods that are on it so I am expecting different jets and there is a guy who sets up alot of the race lads bikes for a very reasonable £80ish (thats over 30 dyno runs).
So the dilema is do I fit the Factory Pro kit and get it dyno'd or just get the guy to set it up on the dyno as the jets etc are similar to the factory pro stuff anyway?
Old 25-05-10, 11:44 AM   #2
TOLAROS
Default Re: Factory Pro Carb kit
Don't use the factory kit.I used to have it but threw it away.Needles not really good tapered,bike kicked like 2 stroke above 7000 and felt lazy in the mids.
Just get a series of Mikuni mains and lift(if necessary) the needle.
Better give the dyno guy the jets and let him do the job.
Old 25-05-10, 05:36 PM   #3
They work fine with just replacement mikuni jets IMO
Old 25-05-10, 06:17 PM   #4
TSM
The Sick Man
TSM's Avatar
there always is two sides to every story
aparently say dynojet needles damage carbs over time while factory pro ones does not, never heard this on the SV though
i know on the ZX7R circles there is a deffo dislike for Dynojets where the carbs have been damaged beyond reasonable repair while factory pro kits are considered the best.
seems each kit has folowers for each type of bike
Old 25-05-10, 07:09 PM   #5
TOLAROS
For me custom tuning(dyno) is the way to proceed.I would never buy a kit because there are so many different combinations for air filters and aftermarket exhaust.No kit will ever work for every combination,that's reality.
I would consider kit for a SPECIFIC combination of air filter AND exhaust.Not to mention that with the kit's cost you can buy jets and cover the cost of the dyno tuning with much better results.
Old 25-05-10, 11:15 PM   #6
hardhat_harry
Its a trackbike so longivity isn't an issue.
I'm just trying to get the most out of the SV without opening the engine.
It has a full Akrapovic system and a BMC race airfilter with the tank raised 25mm and the foam removed so a dyno session will be needed to get the best out of it.
Trying to get to 72bhp
Old 26-05-10, 06:55 AM   #7
TOLAROS
Tank risers won't offer anything.They are used only for fitting FCR.With stock carbs they won't do difference.I tried it and saw no gains.I later verified it by reading this article http://www.svrider.com/articles/2001jul_carbs.htm and you see.
As for foam,I admit I have taken mine off,just for fun.Only advantage is reduced weight ...Bike becomes a bit noisier but I saw no gain in performance.
My bike has full Yoshi and desnorkelled BMC street filter.
PSoes Acrapovic make FULL exhaust for SV?
Old 26-05-10, 07:29 AM   #8
Yes akra make full exhaust for SV... and it is cosmetic improvement only
It will be when it starts running like bag of crap
Old 26-05-10, 10:05 AM   #9
fastdruid
fastdruid's Avatar
My SV with just akrapovic headers and a scorpion silencer made just over 70, stock air filter, I think I had the tank raised 10mm and the foam removed at the time. No jetting changes.
Druid
Old 26-05-10, 10:30 AM   #10
hardhat_harry
The Akra system is ALOT lighter and much less convoluted than the standard system so it should make some gains.
Factory Pro jets 147, 150 0r 152 please mike_red2uk Stuff Wanted 0 08-05-10 01:26 PM
Wanted: Clocks for carb model naked + headlight and carb. Gazdaman Stuff Wanted 2 17-03-10 03:50 PM
Factory Pro kits drag SV Talk, Tuning & Tweaking 32 09-05-09 02:46 PM
pipes going to carb to carb sv650nutter149 SV Talk, Tuning & Tweaking 3 07-09-08 10:16 PM
Factory 2nd exhaust DavieSV Exhausts 0 14-09-07 07:17 PM
