Old 25-05-10, 07:47 PM   #1
markc123
Default Cheap Voltmeter for Bike
Spotted a battery / alternator tester in Aldi this weekend - £3. Since the SV has a history reg / rec issues and I have Heated grips, sat nav, phone charger and uprated bulbs, I wnted to monitor the voltage, but didn't want to pay much to do so .
This little doodad has 3 LEDS for battery - 5v (bad) 12.0v (OK) 12.5v (Good) which are a good indication of battery condition.
Fire the ignition up, and the next 3 LEDs come into play - 13.0v (bad) 13.5v (OK) 14.0v (Good). Thats enough to keep an eye on the charging system.
So the idea is this - take it apart, remove the 6 LEDS, solder a length of wire in line with the LEDs to allow for remore installation - LEDs on dash and the gubbins safe back in the fuse area. Install to ignition live. Job done, and any charging issues should be obvious when out on a ride and therefore reduce chance of stranding.
Heres a few pics, WIP at the moment
The unit stripped down:
The PCB, with LED rail
LEDs de-soldered and ready to rewire:
Cheap bike BigFootIsBlurry Stuff Wanted 7 02-02-09 08:10 PM
Voltmeter Mark_h SV Talk, Tuning & Tweaking 0 18-12-08 06:35 AM
Cheap bike Lozzo Stuff Wanted 12 20-08-08 08:52 AM
cheap sat nav for bike / car steveg Bikes - Talk & Issues 31 21-12-06 12:42 AM
Cheap bike to bike intercoms Viney Idle Banter 6 01-03-06 06:07 PM
