Old 01-06-10, 07:52 AM   #1
AndyBrad
Default bit of a wobble.
Ok i seem to have bevelopmed a bit of a wobble after my little off. It happens about 50mph and upwards. I.ve checked front toback alignment as best i can and it appears to be 1mm out. So im guessing thats close enough. Goung to get the wheels balanced this week, any other things i can check? and how?
Old 01-06-10, 08:34 AM   #2
chasey
Default Re: bit of a wobble.
How did you check the front to back alignment? The 1mm you think you're out - is that including some margin for error within your workings? Surely the only way you can get this exact would be laser?
It's probably in your head. I had an off over a year ago and in some right hand bends I keep thinking my front tire is going to wash out. I remember after my off when I rebuilt the SV, when I first got back on I was 'noticing' things that were probably there from the day the bike was made.
Has anyone else ridden the bike and given there opinion on it?
Old 01-06-10, 08:39 AM   #3
AndyBrad
aye to be fair i am looking out for things but something is definatly up imo. No error taken into account. Just finite values as i was pretty close. I would have thourght this would have been good enough. You can get more accurate than a "lazer" with a bit of cotton but it just takes a lot lot longer...
Old 01-06-10, 09:12 AM   #4
Bri w
Bri w's Avatar
Some of it will be hypersensitivity following your off. The wobble may have been there before but you just weren't looking for anything.
Get the bike checked out professionally.
Either way don't worry, your confidence will return.
Old 01-06-10, 09:18 AM   #5
AndyBrad
yea i must admit it probably was there before but as you say im worried about everything at the mo. Went out for a couple of miles yesterday with tony and figured out that im just a little tense (that pushing through treacle thing i talked about before) things are getting better.
Just wondered if there was another way of checking the forks or something before i take it in?
Old 01-06-10, 09:32 AM   #6
Take caps off and check they are sliding freely up and down, take forks off and get dial gauge on them, DTI the wheels
If it is at one speed then wheel bearings are likely
Old 01-06-10, 09:43 AM   #7
AndyBrad
na 50 and above chap. you cant ride through it (like balancing) so im sure something is buggered.
dti the wheels?
forks run smooth. from what i can tell there not bent but will see if i can get it up in the air this evening at work
Old 01-06-10, 10:03 AM   #8
Well DTI is best way but if you just spin them and can't see a bend then probably fine
Old 01-06-10, 10:15 AM   #9
AndyBrad
yea unfortunatly i only have the mag clamps at work so cant get them on the forks for the wheel you see... will have a look later on and see what it pans out at. I'm at pains to see what those crash bungs did as it appears i bent the rad as well
Old 01-06-10, 10:25 AM   #10
G clamp magnet to caliper mounting tab, works fine on SRAD forks.
But like I say if you spin wheel and cannot see it is bent then it is probably near enough true to be fine
Front end wobble ranathari SV Talk, Tuning & Tweaking 9 17-02-10 07:47 PM
Wobble and instability trev SV Talk, Tuning & Tweaking 11 01-08-09 09:08 PM
Had my 1st wobble last night Nobbylad Bikes - Talk & Issues 11 02-10-08 03:39 PM
Front end wobble? rob13 SV Talk, Tuning & Tweaking 21 05-05-08 09:02 PM
Front end wobble SV andy SV Talk, Tuning & Tweaking 8 26-06-07 07:58 PM
