Old 04-06-10, 01:54 PM   #1
Default -2PSI in a week
Both my tyres have lost 2 PSI since last weekend. Does that seem normal? Is it maybe something to do with the hot weather?
I haven't used the bike all week
The front wheel has a dent in it and I noticed a small cut in the rear tyre last week, so I'm being a bit paranoid just now.
Old 04-06-10, 02:04 PM   #2
Littlepeahead
Littlepeahead's Avatar
Default Re: -2PSI in a week
I replaced the cheap plastic caps with decent metal ones from BMW and it made a huge difference.
Old 04-06-10, 03:29 PM   #3
steveg
steveg's Avatar
Can't see a 2 psi a loss in a week a problem esp with the temperatures varying so much at the moment
Cheers Steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 04-06-10, 03:36 PM   #4
I've got metal valves and caps so it shouldn't be that.
Cheers Steve
Ok cheers
Old 04-06-10, 03:43 PM   #5
TamSV
TamSV's Avatar
Mine have changed by a similar amount. I put it down to the temperature change.
On my other bike the front has lost 20psi in three days. That's down to the big nail in the tyre.
Old 04-06-10, 03:51 PM   #6
dyzio
dyzio's Avatar
I was loosing about 4-5psi, turned out to be the valve. You could try spraying water with washing up fluid on the valve to see if it leaks air.
Old 04-06-10, 05:05 PM   #7
monkey
Or gob onto the schrader. Don't rely on your valve caps to hold ANY pressure! They're to stop dirt getting in and not air getting out.
Old 04-06-10, 06:49 PM   #8
apart from pressure indicator ones...
dont worry about it Daz. BTW dent in the front wheel?
Old 04-06-10, 07:25 PM   #9
Yep
http://forums.sv650.org/showthread.php?t=150836
I think it was a big pot hole in france
Cya next week! Von Teese Guildford Massive 5 14-07-09 07:09 PM
Squires 28/05/08 - this week (not next week like gr33ks post) Paul the 6th Pennine Massive 20 28-05-08 05:15 PM
mid week? (first week october) hovis South & West Surfers 21 08-11-06 08:16 PM
50p Off MCN this week fizzwheel Idle Banter 5 01-02-06 03:46 PM
MFN this week wheelnut The Madlanders 5 27-07-05 07:46 PM
