Old 18-06-10, 08:51 PM   #1
beno987
Default Gear push rod set up
when i was checking round my bike i noticed the gear push rod is loose and bent. Im not sure how long its been like this and if its out of position. How would i set it back into it correct position when straightend or replaced.
Old 18-06-10, 09:03 PM   #2
rigor
Default Re: Gear push rod set up
The push rod is adjustable to alter the position of the gear lever, so there really isn't a "correct" position. Adjust it until you get the lever in a position you are happy with and tighten the lock nuts.
Old 18-06-10, 09:08 PM   #3
beno987
oh thats ok i thought it effected gear changing and should be in a set position.
Push starting an SV 650 K2... trailer_parks SV Talk, Tuning & Tweaking 32 06-08-15 01:35 PM
New Push Bike Help 454697819 Idle Banter 6 23-07-09 01:58 PM
dam push rod seal addicted to rage SV Talk, Tuning & Tweaking 24 09-07-08 03:03 PM
Gis a push Davies Idle Banter 8 18-12-07 11:17 AM
Push or Pull?? Stig Bikes - Talk & Issues 30 12-05-05 10:37 AM
