Old 20-06-10, 02:09 PM   #1
Tim in Belgium
Default Oil behind alternator case on an SRAD.
I'm just patching up my No Budget Cup race bike after our last off.
It went down quite hard on its LHS and broke off the bottom of the alternator cover:
When this happened quite a lot of oil came out of there too.
So a few questions:
1 ) Is there normally oil behind the alternator cover?
2 ) Can oil get to behind the alternator cover if the bike is on its side (laid down)?
3 ) If not either of the above any idea how all the oil got to be there? Or where it came from?
When walking the bike along back to the pits oil only seemed to come out if it was lent over to the left.
Any help on the above is appreciated before I fit the new cover.
Old 20-06-10, 02:58 PM   #2
Default Re: Oil behind alternator case on an SRAD.
Yes, it's inside the engine cases.
If it doesn't there's something wrong.
3 )Or where it came from?
When you changed the oil last time you poured it in there.
The bottom of that case is slightly higher than the bottom of the sump, the oil level clearly is lower than the bottom of that case - hence only leaking when you lay it over to the left.
Old 20-06-10, 03:02 PM   #3
Tim in Belgium
So no big issues then, thanks SS.
I really should get a manual for this bike one day.......
Old 20-06-10, 03:36 PM   #4
I think there is one on carl salter website.
SRAD 750 forks and yokes. SRAD calipers. yorkie_chris For Sale - Other Bikes and General biking items 49 23-01-10 08:06 PM
Alternator gone? Jynx SV Talk, Tuning & Tweaking 3 13-12-09 09:37 PM
alternator case gasket adam_castell SV Talk, Tuning & Tweaking 1 23-11-07 07:58 PM
New Alternator ... How much? The Bride SV Talk, Tuning & Tweaking 13 18-02-07 10:34 AM
alternator dead Warren SV Talk, Tuning & Tweaking 2 16-08-06 05:29 AM
