25-06-10, 01:11 PM | #1 |
Taper roller bearings
Can anyone tell me if the SV uses these in the steering, between the tip and bottom yoke? And also if anyone can recommend somewhere to option replacement ones near Guildford.
Cheers Dan |
25-06-10, 01:21 PM | #2 |
Re: Taper roller bearings
Standard are ball-bearing not rollers. Can't help with where to get them apart from any bearing shop, but I ordered mine (replaced with tapered rollers) on ebay as they were slightly cheaper.
- K9 SV650S: Hel brake lines, carbon end can - SZR660: The project... - K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now) |
25-06-10, 01:42 PM | #3 |
Good afternoon all.
As stated, the standard bearings are caged ball races. I use Honda bearings on Pointys. As, they're exactly the same bearing as Suzuki, but cheaper by a fair margin. You have to use a Suzuki top bearing on Curvy models, as they have a smaller internal diameter than the equivalent Honda part. Alternatively, you can use tapers. The bearing numbers are; 32006 top & bottom on Pointys. 32006 bottom & 32005 top on Curvys. I have all flavours on the shelf Cheers. |
Thread Tools | |
roller discos | Wideboy | Idle Banter | 22 | 31-01-10 07:52 PM |
taper roller head bearings | aermacchi | SV Talk, Tuning & Tweaking | 9 | 13-02-09 08:41 AM |
Roller skates | Keith1983 | Idle Banter | 0 | 28-01-08 10:58 PM |
Help replace stem bearings with taper rollers | zunkus | SV Talk, Tuning & Tweaking | 17 | 20-11-07 07:03 PM |
Motorcycle roller coaster | Nostrils | Idle Banter | 8 | 22-01-07 11:35 PM |
