Old 29-06-10, 12:40 PM   #1
beno987
Default help fitting crash sliders
hi
hope someone can help, ive got some crash slidders but they have no fitting instructions. they are on one metal threded rod that goes through the engine and nuts on each end. My question is which hole to put the rod through? its on a k5 naked, thanks
Old 29-06-10, 02:30 PM   #2
Sruffy
Default Re: help fitting crash sliders
What make are they although I am not sure if that makes a difference.
I fitted R&G crash bungs on my K4 and I had to replace the main engine bolt with the bolt supplied by them. A little daunting pushing the main bolt out but as long as you slide the replacement in at the same time there is no problem. Also make sure you have two socket wrenches (I believe they are 19mm) as you need to tighten/unsrew the bolts at the same time on each side
Here is a link to the fitting instructions on the R&G website. It might give you some idea of what I am trying to say
http://www.rg-racing.com/Images/Prod.../pdf200_60.pdf
Hope this helps dude
Old 29-06-10, 07:36 PM   #3
beno987
thank you, all sorted now
crash bungs / frame sliders pointy 650 & 1000 T.M SV Talk, Tuning & Tweaking 2 27-10-09 06:26 PM
OEM Frame Sliders (crash bungs) Pointy K3+ Sony Tony SV Talk, Tuning & Tweaking 8 27-02-08 02:13 PM
Fitting R&G Crash Bungs DanDare SV Talk, Tuning & Tweaking 9 15-01-08 01:45 PM
crash bungs/sliders for 99 sv650 Styler Stuff Wanted 0 23-07-07 12:26 PM
2006 Suzuki Lower Fairing w/ Frame Sliders (crash bungs) Maestro Bodywork 1 29-11-06 08:35 AM
