Old 30-06-10, 09:04 PM   #1
dazzaboy
Default curvy sv bogs down/loses power?
when going along at a steady speed my bike suddenly bogs down and loses power then it returns after a second? its a 2001 curvy
Old 01-07-10, 12:21 PM   #2
jonny.boyd
jonny.boyd's Avatar
Default Re: curvy sv bogs down/loses power?
No ones going to answer / be able to help you without more information than just that. If you want some help post more details
jonny.boyd is offline   Reply With Quote
Old 01-07-10, 12:45 PM   #3
hongman
I'm certainly not the most experienced but my thought processes are:
Does it tick over ok?
Possibly carp in the tank/fuel filter/carbs?
What speed does it happen, how often?
Do clocks stop working during this bogging down? I.e does rev counter drop to 0?
Old 01-07-10, 01:03 PM   #4
toby_smith
Last thing you want is carp in your tank. I had a similar problem and found this fella in there!
Old 01-07-10, 01:17 PM   #5
hongman
I heard they swim about and help keep the fuel fresh?! Personally I drop a couple of Guppies in once a week
Old 01-07-10, 02:46 PM   #6
That's a Chub and a nice one at that
Old 01-07-10, 02:49 PM   #7
Mine does this if the front plug has got wet. I know we've had no rain for ages, but just check the drain hole (right side) on the front cylinder is not blocked and they'res no water sitting in there?
Spray some WD40 down the plug tunnel
Washed the bike recently?
Old 01-07-10, 11:06 PM   #8
i would say wet plug syndrome as mavi, but without more info its going to be hard
Old 01-07-10, 11:08 PM   #9
Thats a beaut the tank would be the ideal size (brine provided every 110 miles)
Old 02-07-10, 05:40 PM   #10
acer66
Does it only happen at a certain rpm?
If so, a wild guess could be the foam underneath the tank.
Lack of power on Curvy boot SV Talk, Tuning & Tweaking 14 09-02-10 10:23 PM
Fabbri or Power Bronze DB Screen - Curvy Binky Stuff Wanted 1 02-01-10 03:52 PM
Curvy - Ignition controlled electrical power source under pillion seat? TheStudent SV Talk, Tuning & Tweaking 12 02-10-08 06:01 PM
curvy 650 power problem adam_castell SV Talk, Tuning & Tweaking 4 27-08-08 08:30 AM
Curvy looses power after 5000 rpm Jussi SV Talk, Tuning & Tweaking 7 09-07-08 04:31 PM
