Old 04-07-10, 05:47 PM   #1
M65
Default 54mm exhaust on 51.5mm pipework
I could well have just landed a cheap Remus exhaust which apparently is fron a 2003 SV, same as mine. However, I have a three quarter GForce system on mine and the inlet on the can has been measured at 51.5mm. They Remus exhaust I could be getting is 54mm inlet according to the owner.
What I want to know is will the 2 -2.5mm make masses of difference or can I pack it out with some sealant and be aggressive when tightening it up to seal it up nicely? A link pipe for the sake of 2mm seems a bit OTT to me.
Cheers in advance people.
Old 04-07-10, 05:55 PM   #2
Default Re: 54mm exhaust on 51.5mm pipework
When I fitted my Fuel end can I had a similar problem, and it would not have been sorted with aggressive tightening and I don't think packing it out with sealant would have lasted long
I cut a piece off the link pipe supplied with the Fuel can and slipped that over the end of the exhaust pipe. I didn't need the link pipe and it was the perfect size.
But you could do the same with a shim cut out from a tin or alu can. A bit of sealant wouldn't be a problem.
Old 04-07-10, 06:19 PM   #3
M65
The link pipe isnt included with the can so cutting that isnt an option unfortunately. How could I go abou making the shim? Do you mean just cut a regular old bean can, pack it inside the the can and seal it up basically?
Old 04-07-10, 06:44 PM   #4
A beer can works fine for stuff like that.
Old 04-07-10, 06:44 PM   #5
Yep, just a bean can. Alu can would be easier, as you can cut it with a pair of scissors
But I might have a piece of link pipe I can send you
Old 04-07-10, 06:53 PM   #6
M65
If you did that would be awesome! I only need a tiny piece enough to pack out the 2mm or so gap. I guess a piece a couple of cms or so long should be enough. What do you think?
Old 04-07-10, 06:54 PM   #7
PM me your address and I'll pop a suitable sized piece in an envelope
Old 04-07-10, 07:20 PM   #8
M65
Thanks so much for that pal, but now theres no need Im afraid. The **** on eBay has seen has **** after I asked him how he managed to get the exhaust to fit with a 2 -2.5mm gap. Before I could even tell him Id found a link pipe solution, he cancelled the transaction. His loss!
Old 04-07-10, 07:25 PM   #9
What a twonk
Old 04-07-10, 07:36 PM   #10
M65
Tell me about it. Oh well, my money will spend anywhere I suppose. Thanks again for the offer of the link pipe matey.
Micron Pipework - Pointy. lawson17 For Sale - SV's and SV related items 0 03-10-09 08:26 PM
54mm Throttle body butterflies... ThEGr33k Bikes - Talk & Issues 2 18-04-09 09:37 AM
K6-K7 Pipework FG1 Exhausts 3 22-05-08 11:21 PM
Cheaper 99-00 Akrapovic pipework leesvee SV Talk, Tuning & Tweaking 0 29-06-07 08:17 AM
k2 pipework on a K4 Sudoxe SV Talk, Tuning & Tweaking 4 09-05-05 10:27 AM
