Old 08-07-10, 07:50 PM   #1
cF^
Default MOT due, brake light query
MOT is now due on my bike (K3 Naked) and after a quick inspection I've realised that the brake light switch for the front brake seems slightly dodgy. When slightly depressed the light will come on, but holding the brake down with enough force to do anything results in the brake light going off. Releasing the brake light results in a quick flash as it passes the 'sweet spot' where the light seems to work.
I realise this is most likely an MOT failure (not to mention dangerous) but just wanted to check...?
Rear brake switch works fine.
I'm guessing the switch is knackered, problem is it's part of the same piece of plastic that houses the brake fluid resevoir. Anyone know how I'd go about fixing this/finding a replacement? Anyone had the same problem? Any advice appreciated!
Old 08-07-10, 10:02 PM   #2
Default Re: MOT due, brake light query
It's an MOT failure - and not unusual either.
The switch is held to the underside of the brake lever pivot with a single cross-head screw. Remove the switch and fill it with WD40 or similar and press the switch button a few hundred times - often cleans the crud off the contacts and allows the switch to work properly again.
Old 08-07-10, 10:06 PM   #3
cF^
Thank you!
I'll give it a go tomorrow and report back
Looks like an expensive/complicated part to replace should it be entirely screwed and I've not got time to keep the bike off the road that long!
Old 08-07-10, 10:13 PM   #4
Wizzbangwill
Fiver at a bike shop for a pattern one
Old 09-07-10, 04:26 PM   #5
embee
embee's Avatar
Yep, had exactly the same problem with one. The contacts are designed to do a "make and wipe" action, in theory to help keep them clean, but you can get it so that the point where they "make" is clean but the adjacent bit gets burned or cruddy so the light goes off when you pull the brake further. Sid's fix will almost certainly work, otherwise, as said, replacement won't break the bank.
Old 09-07-10, 05:47 PM   #6
cF^
Took it apart, sprayed it with WD40 and it worked! TY very much, this forum beats a haynes manual hands down
Rear brake light Tail Light, Integrated Indicators chrismartin SV Talk, Tuning & Tweaking 11 04-03-10 04:28 PM
Fuel light query. scottjames SV Talk, Tuning & Tweaking 10 28-02-10 02:35 PM
Bolt size and brake query cF^ SV Talk, Tuning & Tweaking 7 04-10-09 05:20 PM
Brake Bleed nipple/Mityvac/Brake Fluid query Ceri JC SV Talk, Tuning & Tweaking 15 20-01-09 02:04 PM
query on connecting new intercom to tail light circuit Johnsilver SV Talk, Tuning & Tweaking 3 28-05-05 04:57 PM
