My lowbeams have stopped working on the pointy sv650s. for the last month the gearside light has been working intermittently (but whenever it failed I just put high beam on) then last week both went out for a stint of riding but they had come back on by the time we stopped up. Now they're not working at all (apart from on high beam).
Any ideas? Sounds very loose connectiony to me but is there a 'low beam' wire/where/what to check? Going to take apart the switchgear but I'm crap with electrics so any other ideas would be a big help. Cheers in advance
simple stuff first, change the lamp, check fuses for good connection
all checked
check you aint got a duff connection at the handle bars or fuses make sure the relay is in properly
Some mods have too much time on their hands!
They were working intermittently - now they have stopped working as per original thread title. Anyhow, double checked fuses and theres no snags or tears in the wiring - does anyone happen to know the colour of the 'low beam' wire? Or any block connectors that it goes through? Cheers
oops, got it - white wire.
http://bolty.net/wp-content/uploads/...lor_wiring.jpg
White by the looks of things Edit: ah you found it |
feed goes from fusebox into right switches (switch normally closed, opens when starter button is pressed), then goes back into loom and to left switchgear (2pos switch hi/lo, soldered wires in feed to switch to allow pass switch to bypass it)
#9 |
ah - didn't check the right hand switch gear. worth a checkles
#10 |
cheers anyway holdup useful 4 future reference.
What I don't understand is why the left one went first ![]() The left light had been intermittent for a couple of months...before they both went. hmm R/H switch seems fine ![]()
Misfire perhaps - running on one intermittently. | stew | SV Talk, Tuning & Tweaking | 19 | 12-04-10 06:04 PM |
Lost Dipped Beam on K3 | I'm_a_Newbie | SV Talk, Tuning & Tweaking | 16 | 01-12-09 10:05 AM |
H.I.D H4 for sv hi low beam | ging6996 | For Sale - SV's and SV related items | 4 | 28-07-09 04:49 PM |
low beam not working. | Slash | SV Talk, Tuning & Tweaking | 3 | 26-09-08 02:28 PM |
Headlamp Beam Deflectors | Banus | SV Talk, Tuning & Tweaking | 4 | 04-04-05 09:21 PM |
