Old 23-07-10, 08:37 PM   #1
Irksy
Default Quick Horn Question
Evening all, horn has given up on my curvy so having a quick look on ebay. Found two, neither are bike specific, ones 6v, ones 12v. Now this may be a stupid question but whats the difference and would either work on my Curvy
Old 23-07-10, 10:33 PM   #2
TamSV
TamSV's Avatar
Default Re: Quick Horn Question
The difference is 6 volts
You want 12v. The current drawn is relevant too. The standard weedy horn draws very little. If you're looking for something louder it will draw more current and you'll need to wire in a relay or you'll blow fuses (at best).
Old 23-07-10, 10:53 PM   #3
Irksy
so is standard 6v or 12v?? sorry relays and electrics in general confuse me!!
Old 23-07-10, 11:10 PM   #4
TamSV
TamSV's Avatar
Standard is 12v. But voltage is not the whole story. The power is made up of voltage and current. The stock horn I believe draws less than 5A. A "universal" air horn replacement could be 20A or more.
There's all sorts on ebay. If you're looking at something that looks like the stock item, is 12v, and not advertised as extremely loud, then you should be fine. If you're looking at sticking on a couple of airhorns you'll need to do some wiring.
Old 24-07-10, 01:05 AM   #5
xXBADGERXx
Stebel horn for the win in my opinion , wiring is easily done and it is awesome to blast people who cut you up ....... they soon know about it lol
Old 24-07-10, 02:02 AM   #6
davepreston
the little blue pill should fix your horn problem dan
Old 24-07-10, 07:25 AM   #7
Weirdfish
Are you sure your horn has had it? Tried a disconnecting the contacts squirting with WD and cleaning 'em up a bit?, Sometimes just wobbling the contacts whilst depressing the button will bring forth a starngled horn back from the dead! It's lack of use you know!
Old 24-07-10, 11:33 AM   #8
Jayneflakes
Jayneflakes's Avatar
I also moved mine from behind the radiator because every time it got hot, it stopped working. It is now mounted on the bottom yoke with a new wire and a nice stainless steel bolt.
Jayne you're a Pussy Magnet
Quick E Bay Question Quiff Wichard Idle Banter 11 31-07-08 11:54 PM
FIAMM Horn question Ceri JC SV Talk, Tuning & Tweaking 11 18-10-07 06:26 PM
FIAMM Horn question JeremySV650 SV Talk, Tuning & Tweaking 11 04-10-06 03:16 AM
Quick question Ward8124 Bikes - Talk & Issues 1 13-04-06 09:03 AM
Quick Question, Quick Answer JakeRS SV Talk, Tuning & Tweaking 6 07-05-05 11:00 PM
