Old 24-07-10, 04:34 PM   #1
beabert
Default Fitting a clip link on a xring chain.
Any ideas how i can get this on.
My idea was to fit a clip/spring link, ride to the bike shop and have it replaced and rivetted, but i cant get the clip link on, impossible to compress the plates enough.
Any reckon i could leave the xrings out of the one side and ride sedately to the shop 1 mile away? cant see it hurting.
Old 24-07-10, 05:02 PM   #2
Default Re: Fitting a clip link on a xring chain.
Probably it is friction of plates not the rings which is causing the problem.
I doubt 1 mile will cause an issue.
Old 24-07-10, 05:08 PM   #3
beabert
Im out of options now, other than pushing it lol.
Old 24-07-10, 05:09 PM   #4
You normally need a G clamp to push it on
Old 24-07-10, 05:12 PM   #5
beabert
Yeah, i just dont see how i get the spring link in, if a clamp is in the way. Ill need to knock up something.
10mph over 1 mile should be fine.... lol
Old 24-07-10, 05:15 PM   #6
Friction keeps it there normally
Get an 8mm spanner, put that over hole in link, press it on so pin goes through hole in spanner. Do each pin a little at a time so it does not go on on the p*ss
Old 24-07-10, 05:23 PM   #7
beabert
I can get it over the pins, its the xrings pushing back thats my problem, i cant see the groove for the clip to slide into. I think two spanners about 20mm and a clamp might work as a plate compressor. Ill have a go tomorrow, its so frustrating, im so close lol.
edit: no that wont work lol, slide need somewhere to slide the clip. ffs.
edit: The plate from the rivit link would hold it on by friction, but the clip link plate are designered to slip on easier.
Old 24-07-10, 05:29 PM   #8
beabert
http://www.youtube.com/watch?v=-lFFePQlVc4 @ 7 mins, i wish! lol no xrings on his.
Old 24-07-10, 05:58 PM   #9
beabert
all on and bodged.
Old 25-07-10, 11:06 PM   #10
beabert
Unbodged, went on easy today, god knows why its like a different bike!
Fitting Clip ons gavinsky23 SV Talk, Tuning & Tweaking 5 14-06-09 10:59 AM
Clip link chain help! natcar SV Talk, Tuning & Tweaking 16 20-12-08 07:01 PM
Fitting aftermarket mirrors to clip-on bars chakraist SV Talk, Tuning & Tweaking 0 13-02-08 01:40 AM
Clip type master link yorkie_chris SV Talk, Tuning & Tweaking 20 08-11-07 06:02 PM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
