Old 30-07-10, 09:30 AM   #1
cb1000rsteve
Default A garage I recommend. Service.
Great Garage to use in the tees Area is Frontline motors, South bank middlesbrough. £80 for a full service. nearest competitor was £140!!!
The guy is a real straight talking fella and as a bonus he likes the SV as its simple to work on and in his words is a solid reliable bike.
tel No. 01642 452426
Old 01-08-10, 03:02 PM   #2
Default Re: Garage Service
What's his idea of a full service?
Old 01-08-10, 07:31 PM   #3
cb1000rsteve
Default Re: A garage I recommend.Service
Mines done just over 10,000. said he'd check compression and if crap he'd do the valve shimming, but they don't usually need doing till later. Then the usual and an all round check. Probably the same as the bloke charging £140 except i keep 360 in my pocket :^)
Old 01-08-10, 10:52 PM   #4
Not sure I agree with using compression test to check valve clearance, but since that check is not due anyway I would not say it's a bad check to do.
Old 02-08-10, 06:47 AM   #5
Bri w
Bri w's Avatar
I've used Frontline, and can add that the guy really knows his stuff. He's quite happy for you to be in the workshop when he's working and willing to explain what he's doing and why he's doing it.
Last service I had done I asked about about iridium spark plugs. He said he would get them if I wanted them but that they were expensive for the marginal benefit they gave to the average biker, especially as a lot of bikers also change their bikes relatively frequently. He also fitted two new tyres a lot cheaper than anywhere else locally.
Recommend Me... A Garage Heater squirrel_hunter Idle Banter 27 21-11-09 09:48 PM
Recommend me a garage in the Teesside area for 15k service (inc valve clearances). Tim in Belgium Pennine Massive 8 27-07-07 11:18 AM
Recommend a MOT garage??? quikstu SV Ecosse 18 01-05-07 08:53 PM
Anyone recommend a decent garage bucks/berks area? ASM-Forever SV Talk, Tuning & Tweaking 6 31-12-06 06:44 PM
Recommend Dyno and Servicing garage Saracen Soho Massive 1 29-04-06 06:10 PM
