Is the Ignition Advance Kit worth getting as its only £60 ?
apparently you need to run higher octane fuel, but also apparently the sv i made for 85 fuel and uk fuel is 90+ (dont ask me about details i have no idea what the fuel types are) so apparently uk standard fuel would be fine ? any info at all would be good PS it would have to be installed by proper mechanic as i dont have a impact drill this is its apparent gains but i take them with a pinch of salt ![]() |
For road riding I'd spend your money on something else personally. Unless you are going for maximum tuning and getting it set up properly on a Dyno, its not really worth it. That was the info i got when looking at tuning my Kwak.
im wanting to get it set up on the dyno some time soon, not going for maximum tuning just cheep ish mods that could help
thanks |
You can get the same effect (whose gains are questionable) for free. Think about how it works.
4 degree ignition advance does it work on a K6? | Jackie_Black | SV Talk, Tuning & Tweaking | 25 | 23-07-08 10:35 PM |
offset woodruff key / ignition advance | adam_castell | Stuff Wanted | 0 | 12-11-07 02:52 PM |
Offset Woodruff key to advance ignition by 4° | Richie | SV Talk, Tuning & Tweaking | 1 | 22-07-07 06:20 PM |
Cam swap, ignition advance, jetting? | pod | SV Talk, Tuning & Tweaking | 26 | 31-05-07 12:04 AM |
Ignition advance key and carb adjusting | Fuzz | SV Talk, Tuning & Tweaking | 3 | 18-08-05 12:27 PM |
