Old 02-08-10, 08:41 PM   #1
KaWySiCkHuNdReD
Default newer R6 throttle on SV?
just wondering if anyone has tried the newer r6 (06-up) throttle tube for the SV? I was told it was a 1/6 vs the 1/5 turn on the older R6.
And if you did any differences in filing vs the older r6 tubes?
thanks
Old 03-08-10, 07:53 AM   #2
Berlin
Default Re: newer R6 throttle on SV?
72 degrees too much for you? You need 60 degrees?
You must have tiny hands!
No wonder bikes are getting "mode" settings if the fine throttle tuning is being reduced! 120 horses through 1/6th of a turn is a scary proposition, even more so in the wet!
Old 03-08-10, 04:51 PM   #3
KaWySiCkHuNdReD
I have a scaphoid bone injury......
the less twist the better.
Old 05-08-10, 02:32 PM   #4
KaWySiCkHuNdReD
any thoughts guys?
Old 05-08-10, 02:47 PM   #5
danf1234
yeah buy an R6.
Pointy petrol tank - K3 or newer flymo Stuff Wanted 0 25-05-09 08:57 PM
SV650s 1999 V-reg model or newer... v15hal Stuff Wanted 19 25-04-08 02:20 PM
Swap Old Engine into Newer SV? wmrra#30 SV Talk, Tuning & Tweaking 5 21-09-06 11:10 AM
Wanted : Factory Restriced Sv650 K2 or newer pollypigwash TOTALSV Ireland 1 07-09-06 08:47 PM
SV650s Older models with newer mods sprocket SV Talk, Tuning & Tweaking 5 17-01-05 12:02 AM
