Old 03-08-10, 07:23 AM   #1
Sally
Default Pointy Black Plastic Clock Surround
As per title, anyone got on going?
Old 04-08-10, 01:51 PM   #2
Nobbylad
Nobbylad's Avatar
Default Re: Pointy Black Plastic Clock Surround
I've got one with a hole drilled for the on/off switch for some heated grips, about the size of a 10p and I think the thin bit on the left hand side might be cracked but could easily be plastic welded/soldered.
Let me know if that's any use and I'll try and sort out photo's
Old 04-08-10, 01:59 PM   #3
Owenski
if he doesnt nobby, let me know.
Im looking for one to test build a sav nav mount.
Old 04-08-10, 11:06 PM   #4
Nobbylad
Nobbylad's Avatar
Some pics...
One of the mounting lugs is broken off as you can see in this one. The surround I have on at the mo is exactly the same and I've just screwed a small screw into the shoulder where the lug was and that locates nicely into the rubber grommet on the subframe.
Old 05-08-10, 08:50 AM   #5
Owenski
Thats spot on nobby, again if Sally doesnt want it let me know what your after.
Wanted: Pointy Brake Lever & Clock Surround Sally Stuff Wanted 6 12-03-10 12:37 PM
Wanted: black plastic nose trim for pointy S. skapegoat Stuff Wanted 1 10-08-09 08:46 PM
inner clock fairing surround 2003> (pointy) shiver85 Stuff Wanted 11 22-06-09 09:10 PM
SV Pointy Clock Surround MiniMac For Sale - SV's and SV related items 1 27-01-09 12:13 AM
ripple on the clock surround - pointy blueto SV Talk, Tuning & Tweaking 13 03-03-08 08:31 PM
