Old 06-08-10, 05:37 PM   #1
kenboy
Default Removing the oil sump?
Can anyone tell me is it difficult to remove the oil sump Does it involve removing the exhaust
Old 06-08-10, 05:43 PM   #2
Nicky S
Nicky S's Avatar
Default Re: removing the oil sump
nope easy as and you do not need to remove the exhaust what bike and year do you have ?
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 06-08-10, 09:25 PM   #3
If you're referring to removing the drain plug to do an oil change then no, the exhaust doesn't need removal.
If you actually wish to remove the oil sump then there's a problem - there isn't one. The SV crankcases are vertically split and there is no separate sump.
Sump Plug - where from? toby_smith SV Talk, Tuning & Tweaking 6 11-07-10 10:53 PM
oil sump washer steveg SV Talk, Tuning & Tweaking 7 12-10-09 11:55 AM
Oil Sump washers. Baph Bikes - Talk & Issues 4 06-05-09 08:28 PM
coolant in sump oil greenzombie SV Talk, Tuning & Tweaking 11 30-03-07 01:02 PM
