Old 06-08-10, 08:51 PM   #1
minimorecambe
Default Number plate touching tyre.
OK this may be a really thick thing to ask!
Took the SV out for the first time yesterday (me pillion).
Got up to Devils Bridge to see that the number plate had been touching the tyre the whole way there New number plate needed now
Why would this be?
Does the suspension need sorting out?
Help!!!
Old 06-08-10, 09:37 PM   #2
Default Re: Suspension
check what the preload is on it maybe on the lowest, but the shock may be finished
Old 06-08-10, 09:42 PM   #3
Mr Speirs
Mr Speirs's Avatar
Preload, when carrying pillion it is advised to increase preload on compensate for the extra weight. If however you both weigh normal amounts chances are you are already to weighty for the original shock to handle anyway, in which case it's stop riding two up with that amount of weight or uprate the shock.
Old 06-08-10, 09:50 PM   #4
The suspension should move through its entire travel, knackered or not, without the numberplate hitting anything.
Work that out first, then think about whether the suspension is working properly.
Old 06-08-10, 09:52 PM   #5
minimorecambe
Default Re: Number plate touching tyre.
Im only just learning about bikes and the mechanics so you will have to bear with me Im afraid.
Old 06-08-10, 10:26 PM   #6
Icanopit
Has the rear suspension been lowered?? + as above.
JOHN
Old 06-08-10, 10:38 PM   #7
Can't the angle/position of the numberplate be adjusted?
Old 06-08-10, 10:40 PM   #8
nope unless stuck out well clear of the bike or hung from the swing arm
Old 06-08-10, 10:41 PM   #9
Some tail tidy's you can adjust. Well mine can anyway
Old 06-08-10, 10:48 PM   #10
Some do adjust.
It sounds like its a shock issue when pillion weights are on the shock
2008 Tail - inc Indicators, Number Plate Light and Number Plate Holder cbay For Sale - SV's and SV related items 14 14-03-10 11:36 PM
number plate wilky007 SV Talk, Tuning & Tweaking 18 09-02-09 09:28 PM
number plate Wideboy South & West Surfers 37 02-10-08 02:39 PM
Tail Tidy - Number plate catches tyre... joeheaven SV Talk, Tuning & Tweaking 19 13-03-07 07:34 PM
Back tire touching licence plate! thor SV Talk, Tuning & Tweaking 15 14-06-05 01:57 PM
