Old 08-08-10, 04:55 PM   #1
dazzaboy
Default carb fuel/running problem
put some new carbs on today and got some problems, the front slider does'nt seem to move like the rear one unless you rev it up high then it moves very slightly? also on the front carb i cn't see fuel going in like on the rear one but seems to rev up ok so im guessing there is fuel getting in. idle is ok and then on its own it occasionally wants to idle about 3k then drops after a while and pops alot??? need some help please. its a 2001 curvy
Old 09-08-10, 06:56 AM   #2
Default Re: carb fuel/running problem
diaphragm split? crap stuck in slideways?
Old 09-08-10, 05:07 PM   #3
dazzaboy
changed diaphram and cleaned yesterday still no better tho :/ i dunno where to start
Old 09-08-10, 05:09 PM   #4
does the slide move up with finger pressure and feel same as rear?
Old 09-08-10, 05:39 PM   #5
dazzaboy
i can slide it with my finger and it feels ok but when i let it go its seems to go back quicker than the one on my rear carb? does the fuel push the slider back when revved up?
Old 09-08-10, 05:42 PM   #6
air pressure does. Engine creates vacuum and "sucks" it up. if it is returning faster then it does sound like diaphragm is somehow not sealed or has hole.
Old 09-08-10, 05:47 PM   #7
dazzaboy
gonna have another look but strange how its exactly the same after i changed the diaphragm :S
Running poorly - carb stuck on choke. emc_andy SV Talk, Tuning & Tweaking 5 31-12-11 04:24 PM
Carb peeing petrol and running on 1 cylinder BigBaddad SV Talk, Tuning & Tweaking 2 22-03-10 11:08 AM
running problem - as if running out of petrol Nick8529 SV Talk, Tuning & Tweaking 20 27-10-09 11:47 AM
Poor running after carb balance. hallasv SV Talk, Tuning & Tweaking 14 07-08-09 06:04 PM
Carb balancing, poor running Jimbo_Bimbo SV Talk, Tuning & Tweaking 8 24-11-08 11:59 PM
