Old 13-08-10, 03:14 PM   #1
Gene genie
Default blue smoke
okay people, pointy me in the right direction. on way home from work heard a bit of a clunk and thought oh oh. pulled over, engine seems fine, ticking over nicely, nothing out of the ordinary, then i notice a hint of blue smoke and my heart sank. revved it a little and a plume bellowed out.
i was planning on a trade-in, but thats now in doubt.
Old 13-08-10, 03:24 PM   #2
Berlin
Default Re: blue smoke
Blue smoke is never good.
Best case scenario is the oil is coming from the engine breather back into the air box, but that's unliklely.
Something in the top end isn't happy. Stripdown is probably the term going to be used.
C
Old 13-08-10, 03:27 PM   #3
Sadly the above advice is probably true. I'd do a compression test first, it could possibly save unnecessary work.
Old 13-08-10, 03:40 PM   #4
Gene genie
i know its friday the 13th so i dont need frightening anymore. do you think its worth floggin on ebay as a whole bike as spending money on it is not an option that interests me in the slightest.
Old 13-08-10, 03:49 PM   #5
You will lose money on it either way
Old 15-08-10, 04:15 PM   #6
Gene genie
carried out a compression test sid squid, as you advised, and discovered both pots were 115psi and 120psi. dropped a little oil in each chamber and got 220psi and 225psi so its the pistons and barrells etc.
decided to scrap bike which has broken my heart but will use it as an excuse to invest in something with a little more kick.
thanks again people for your thoughts.
Old 15-08-10, 06:05 PM   #7
Berlin
What is the compression range for a good engine? They seem pretty high for a scrapper.
C
Old 15-08-10, 06:31 PM   #8
The difference there suggests somethings f*ed.
However, used pistons and barrels are cheap... lots of engines blown their big ends and left rest of it unscathed. Easy fix
Old 15-08-10, 07:43 PM   #9
Gene genie
not one to mix your words are you chris.
Blue smoke and loss of power Elky SV Talk, Tuning & Tweaking 9 29-01-09 10:27 AM
What I did in the big smoke... Stingo Idle Banter 0 03-11-08 10:06 PM
Hello from the Big Smoke! Jester666 Thames Valley 37 17-08-07 11:42 AM
blue smoke :S BIKER-DENE Bikes - Talk & Issues 3 08-07-06 06:38 AM
blue smoke out of a carbed raptor 650! wreckah SV Talk, Tuning & Tweaking 10 26-04-05 10:10 AM
