Old 16-08-10, 10:43 AM   #1
ThEGr33k
Default SAS storage
At work we are looking to build a SAS storage system... Now I have the cards all figured out (man there isnt much info about) and I look like getting 2 8 channel cards for 16 HDD.
The main question is;
You can use SATA HDD on SAS cards, but does this mean that the SATA HDD can run at full duplex when combined with a SAS card? I know SAS card to SAS HDD can do that fine. SO basically can a SATA HDD handle full duplex?
Old 16-08-10, 10:50 AM   #2
Geodude
Geodude's Avatar
Default Re: SAS storage
Wish i was clever enough to know what any of this means
Old 16-08-10, 10:55 AM   #3
Jackie_Black
Can HDD's ever be full duplex? Surely they either read or write.
I would like to know how fast this thing moves data when you get it finished!!
Old 16-08-10, 02:59 PM   #4
appollo1
appollo1's Avatar
phew.....i thought i was the only one that was reading this mysterious code and couldn't work it out!!
i'm not old i'm experienced!!
http://www.german-shepherd-rescue-scotland.org.uk/ everyone deserves a second chance
RIP Appollo miss you and will always love you x x x x
appollo1 is offline   Reply With Quote
Old 16-08-10, 03:10 PM   #5
ThEGr33k
Me too...
Obviously they cant physically do read and write but I think the full duplex helps with data requests etc. We arnt sure what we are going to do yet... Weather 20 500GB 7200rpm SAS discs or something a little smaller but faster RPM...
Old 16-08-10, 03:25 PM   #6
Daimo
We have a 16tb SAS and its running dual fibre lines to our other boxes.
So 2gb data transit.
Old 16-08-10, 10:04 PM   #7
Jackie_Black
That's awesome!
Old 16-08-10, 10:10 PM   #8
TSM
The Sick Man
TSM's Avatar
what are you storage requirements? ive been looking at these things for some time so know a fair bit
There are new cards that you can put full SATA disks in then a single SSD drive to accelerate the reads, all depends on your workload. LSI Cachecade and Adaptec MaxIQ are these type of systems.
Old 16-08-10, 11:35 PM   #9
ThEGr33k
Well we currently have a 10 driver SATA Raid 5 and we seem to be getting long access Ques... What we want is high capacity if possible with more speed... Would 7200rpm SAS disks be any faster than 7200rpm SATA discs? Id have thought 10k or even 15k discs are needed to speed I/O which is a potential bottle neck atm?
Other problem is we are trying to keep cost down, pretty hard with storage we are finding, which is why SSD's arnt high on the list, that and stone think that they arnt so good, though im not sure where they are getting that from?
Or alternativley, is there any way to get rid of the access ques with the kit we have? We are using a mobo with 10 SATA build in, would it be better for example to just put some SAS cards in that system? Would that eliviate the bottlekneck?
Old 17-08-10, 09:11 AM   #10
TSM
The Sick Man
TSM's Avatar
SAS vs SATA at 7200 has hardly any diffrence in it and under some tests has shown to be slightly slower.
Going for 10k vs 7.2k depends a little on the workload itself, also applys to if you go for 3.5" vs 2.5" as the smaller ones have a lower access time than their larger counterparts but come at a cost.
Are you mainly looking at reads or writes on your system, what raid card are you currently using, what is the dataset like, large file reads or lots of small reads etc..
I would not go for SSDs on main storage filers but my angle was the SSD drive on the cards i listed is a read acclerator (ie 64gb of RAID cache), if it breaks then you dont loose anything apart from speed as the data is still all on the disks until you change the drive.
Look at RAID 6 instead of RAID 5 when working with large SATA/SAS filers as the rebuild time will be realy long and you could have a second disk fail while the rebuild is happening, it means more disks but it will save your nuts in the long run also you will probably need your filer to be larger because you will need again more disks to eak out the IOs.
I use the WD RE4-GP disks, they are only 5.4k but they are faster than my 3yr old Seagate ES.2 7.2k disks, there are the RE4 disks which are even cheeper but come with nearly a 25% price hike each.
You would be surprised how much the speed actualy has to do with the raid card itself, a better card may work out well but note you cant transition from one card to another, somtimes if you stay with the same make you can, i have HP cards and you can go up/down the range as long as each card supports the config you had before.
Pointy K5 Storage Vespillo Bikes - Talk & Issues 19 15-09-08 01:17 PM
Storage and starting svmad SV Talk, Tuning & Tweaking 5 26-09-07 08:59 AM
After 9 months in storage what will need doing? B SV Talk, Tuning & Tweaking 9 17-06-07 08:05 PM
bike storage Dave The Rave Bikes - Talk & Issues 11 08-12-06 05:19 PM
Email Storage M65 Idle Banter 8 05-09-06 04:17 PM
