Old 18-08-10, 06:33 PM   #1
Stingo
Stingo's Avatar
Default Front brake reservoir change questions.
Changing the reservoir tommorrow. Got tools. Got oil. Got rags. Need top tips! For example, do I need to apply the front brake and tywrap the lever to the grip before I remove the old reservoir? I'm hoping to get away without having to drain the whole shebang...
Twitter: @poseidon_ashore
Old 18-08-10, 07:59 PM   #2
Razor
Default Re: Front brake reservoir change
if you did that when you loosened the banjo fluid would spray everywhere
loosen the m/cyl banjo, use a cloth/pastic bag to stop brake fluid destroying paint/plastics
unbolt m/cyl and then unbolt banjo
replace m/cyl
bleed brakes
Old 18-08-10, 08:01 PM   #3
Holdup
Razor i think Stingo is only changing the reservior not the whole mc, if the is the case i suppose, just make sure you dont spill brake fluid every where
Old 18-08-10, 08:06 PM   #4
Stingo
Stingo's Avatar
Thanks Razor although...
It is the reservoir I'm changing and not the master cylinder..as far as I can see the pipe from the reservoir is very easily disconnected, I just need to ensure that I don't get air into the wrong side of the m/cylinder...
Having said that I will bow to your superior knowledge...
Old 18-08-10, 08:43 PM   #5
No, think about it. Fluid flows downhill, if you don't take any fluid out below the res, you won't need to replenish any below the res.
But, fresh brake fluid is always good.
Old 18-08-10, 08:50 PM   #6
Just flush it anyway. It would be daft not to. Doesn't take long
Old 18-08-10, 09:07 PM   #7
Stingo
Stingo's Avatar
This is what I thought...the fluid in there is fairly new (March this year) as I had the pipes replaced for s/s ones.
Old 18-08-10, 11:44 PM   #8
Razor
Default Re: Front brake reservoir change questions.
ahhh, see what i get for not reading properly
anyway, i'd then empty the res with a syringe, put new one on and re-fill
bleed as required
Old 19-08-10, 08:03 AM   #9
Stingo
Stingo's Avatar
Thankyou Razor et al, all done now, took about ten minutes...just in time for the second coffee break.
Front brake reservoir K3 S Stingo Stuff Wanted 1 14-08-10 01:22 PM
Wanted- Front brake reservoir. injury_ian Stuff Wanted 6 10-06-09 09:45 PM
front brake reservoir hose -Ralph- SV Talk, Tuning & Tweaking 21 14-02-09 10:18 PM
Front brake reservoir svrash Stuff Wanted 2 31-10-06 10:05 PM
Front brake fluid reservoir Sloth Stuff Wanted 1 21-12-05 10:52 AM
