Old 19-08-10, 08:43 AM   #1
appollo1
appollo1's Avatar
Default Car problems - mechanics advice please
As I am no way mechanically minded for cars or bikes I need some help and advice form any mechanically minded folk out there please.
My car is 13 years old and has just had a full service and timing belt changed. I have been detached away with work in Lincolnshire and drove down from Scotland a few weeks ago.
Everything was fine on the motorways until I got into the side roads. Sometimes (not all the time) when I changed down to 4th or 3rd the car just revved like crazy and i had to feather the accelerator pedal for it to finally pick up the gear.
My Father in law had a look and he says that the clutch and gearbox are all ok (he worked for the RAC for 30 years so knows what he is talking about). The clutch is not slipping and it only seems to happen after a longish time on the road. I have done a few journeys since on the country roads round here and it appeared ok.
I need to use the car every other weekend to get home for the next 7 weeks (350 ish miles each way) and need it sorting.
I don't want to put it into a garage to be checked as i can't afford a huge repair bill or a huge bill for investigation.
Any serious thoughts on what it may be would be greatly appreciated.
i'm not old i'm experienced!!
http://www.german-shepherd-rescue-scotland.org.uk/ everyone deserves a second chance
RIP Appollo miss you and will always love you x x x x
appollo1 is offline   Reply With Quote
Old 19-08-10, 08:45 AM   #2
Default Re: Car problems - mechanics advice please
Sticky throttle cable or linkage. Maybe its binding somewhere after all that work you had done to it
Old 19-08-10, 10:14 AM   #3
Mr Speirs
Mr Speirs's Avatar
What car is it?
Old 19-08-10, 10:38 AM   #4
SVforvictory
Originally Posted by appollo1 View Post
...when I changed down to 4th or 3rd the car just revved like crazy and i had to feather the accelerator pedal for it to finally pick up the gear.
When the revs rose did the car lurch about at all or did it feel like the clutch was in?
Old 19-08-10, 12:20 PM   #5
think you may have hit the nail on the head. its a skoda if i remember and i think they use a hydraulic clutch.
so it might be a sticky clutch slave cylinder.
Old 19-08-10, 12:26 PM   #6
Blocked return in clutch master cylinder meaning fluid has nowhere to expand to when hot... thus disengaging the clutch all the time
Old 19-08-10, 06:36 PM   #7
svtomo
when does it rev up, when you dip the clutch or when the clutch is let out and you try and accelerate?
Old 19-08-10, 07:57 PM   #8
Spikenipple
Spikenipple's Avatar
Take it back to wherever you got it serviced and tell them it didn't happen before they worked on it.
Had: K7 SV650S in Candy Sonoma Red
Now: MT-09
My old SV
South & West Surfer
Spikenipple is offline   Reply With Quote
Old 20-08-10, 08:10 AM   #9
appollo1
appollo1's Avatar
the car is a 1997 Skoda Felicia 1.6 GLXi
I would take the car back to where all the work was done but it was done by my father in law and it was doing it a little bit before i got all the work done.
It happens when I change down to 4th or 3rd and when I go to accelerate after releasing the clutch, it's like i still have the clutch pedal pressed down and it just revs.
I'm reluctant to put the car into a garage to have it looked at in case they just go for the easy option and tell me i need a complete new clutch.
Old 20-08-10, 11:19 AM   #10
embee
embee's Avatar
If it's hydraulic then the earlier diagnosis sounds right. First thing is simply change the clutch fluid (very often it's from the brake fluid reservoir). Even if the brake fluid has been changed in living memory, it's quite probable that the clutch side hasn't, I've seen stuff come out of them which looks like chocolate mousse.
Any vechile mechanics or learning mechanics? ManxMatt34 Idle Banter 23 06-11-09 08:27 AM
Any car mechanics..... arcdef Guildford Massive 6 17-09-09 07:05 PM
Any car mechanics.... arcdef Thames Valley 2 16-09-09 07:26 AM
Any car mechanics here? StreetHawk Idle Banter 13 19-08-08 11:42 AM
Advice please, Problems with my landlord gettin2dizzy Idle Banter 26 09-08-07 11:47 AM
