Old 21-08-10, 09:08 PM   #1
Nicho..!
Post SV flat battery - causes?
Went to work yesterday, bike was fine, came out of work that night, put the key in and nothing, no lights, ziltch..! Got the mechanic out, started the bike with a booster, it fired up, but with protest, sputtering, miss firing, dying out and back firing, rev counter was also dropping off then on again when revs were high, finally popped loud and died. I have no bike knowledge and any help or ideas would be gratefully recieved.
Thanks in advance, Nicho..!
Old 21-08-10, 09:37 PM   #2
suzukigt380paul
Default Re: SV, died in it sleep..!
hi had a similar problem on my bandit 6,and it was a dead battery,replaced battery and all is well again.
Old 21-08-10, 09:45 PM   #3
aaron020873
i'm no mechanic but if it started with a booster, i would change the battery to start with, batteries can be fine one minute and then dead the next.
Old 21-08-10, 09:53 PM   #4
Razor
take battery out and charge it up, then put it back in and check charge rate
Old 21-08-10, 10:04 PM   #5
suzukigt380paul
9 times out of 10 if the battery is flat it wont take a charge evan if the battery isnt terminally dead,modern batteries dont like being run down,the fastest way to charge it is with the engine running if it will charge at all,and never use a car charger,
Old 22-08-10, 12:25 PM   #6
Did you leave the parking light on, or do you have an accessory that you could have left powered?
Did the bike start normally before the problem incident? How did it run on the prior trip?
Diagnosis requires information not guesses - there isn't enough info in your first post to make ANY realistic diagnosis.
If the battery was only flat - whatever the cause - during the time that you were at work it won't have been damaged by that, (which is not to say it's not damaged, it could be the problem but leaving it flat for for a few hours won't hurt it).
Car charger will be fine, charging time will need to be adjusted to account for charge rate.
Answer the questions first before spending money on batteries or anything else.
Old 22-08-10, 12:27 PM   #7
Lozzo
Default Re: SV flat battery - causes?
The magic fizz has run out. Batteries are like bottles of pop, if you shake them they go flat.
Avoid bumpy roads.
Flat Battery? Rob84 SV Talk, Tuning & Tweaking 14 02-03-10 10:37 PM
flat battery jimc SV Talk, Tuning & Tweaking 5 15-01-09 10:32 PM
Flat battery? appollo1 SV Talk, Tuning & Tweaking 8 19-05-08 06:05 PM
Help...flat battery KnightRider Bikes - Talk & Issues 27 12-11-07 02:44 PM
FLAT BATTERY!! philb SV Talk, Tuning & Tweaking 5 19-05-05 10:42 AM
