Old 23-08-10, 08:35 PM   #1
muzikill
muzikill's Avatar
Default Front sprocket pointy, socket size needed?
as it says does anyone know the right size? - ive consulted all the manuals and none give the size away! - i've tried to measure it but it's in a awkward position & not easy to find out ..............
Old 23-08-10, 08:35 PM   #2
Default Re: Front sprocket pointy, socket size needed?
32
Old 23-08-10, 09:07 PM   #3
beabert
Indeed
Old 23-08-10, 09:58 PM   #4
keith_d
keith_d's Avatar
I found my regular socket set didn't go up to 32mm so I ended up buying a six-point impact socket. Shouldn't break that one any time soon.
Keith.
Old 30-08-10, 04:49 PM   #5
muzikill
muzikill's Avatar
32 was spot on the right size.. had to buy one out of halfords for £6 quid ... to confirm all sockets sets that have this size were expensive so it was not worth buying a whole set just for one.
Thanks.
Old 31-08-10, 07:02 AM   #6
timwilky
timwilky's Avatar
What, you are a tool amateur. My sockets go up to 60mm. Ask Andy Saxon I showed him the big boys set. My little boys set goes to 34 and I have a 36 in the tote box for the back axle nut
Not Grumpy, opinionated.
socket size front sprocket? beabert SV Talk, Tuning & Tweaking 2 23-07-10 04:46 PM
Front sprocket nut size? Bikermike59 SV Talk, Tuning & Tweaking 9 03-10-09 11:18 AM
Front sprocket Nut size glade SV Talk, Tuning & Tweaking 5 06-08-07 09:54 AM
Front sprocket nut size please? slippery SV Talk, Tuning & Tweaking 2 23-07-05 06:03 PM
what size bolt for the front sprocket wigan650s SV Talk, Tuning & Tweaking 3 23-01-05 10:42 AM
