Old 24-08-10, 07:36 PM   #1
minimorecambe
Default Slightly nervous now
Starting to get nervous about tomorrow now.
I have my module 2 test
Any last minute tips? Obviously I know not to drop the thing (have already done that so need to do it again!)
Old 24-08-10, 07:39 PM   #2
allantheboss
Default Re: Slightly nervous now
Doesn't matter if you get lost (Well, it didn't in the old style test)...
Also, they can only keep you for something like 40 minutes, so you can get your friends to stage a crash outside the test centre so you have to wait, then just do a u-turn and pass with 0 minors!
Old 24-08-10, 08:08 PM   #3
kellyjo
Just remember your lifesavers..... and relax!!
Its much easier than Mod 1 and if i can pass with a clean sheet then i assure you anyone can!!
Try and enjoy it, best of luck, KJ x
Old 24-08-10, 08:11 PM   #4
MisterTommyH
MisterTommyH's Avatar
Relax and remember your lifesavers.
Also a quick look down to make sure you have hit the indicator when you think you have.
Good luck!
MisterTommyH is offline   Reply With Quote
Old 24-08-10, 08:11 PM   #5
Baggy
Take a couple of paracetamol about 30 mins before, it helps with nerves
Old 24-08-10, 08:12 PM   #6
look at where you are going, not at the floor when you do that U turn.
Old 24-08-10, 08:13 PM   #7
minimorecambe
Glad I dont have to do a U-turn again!!!
Thanks for that advice Baggy - I will try that
Hope the weathers better than it was today!!!
Old 24-08-10, 08:37 PM   #8
Treacle
Treacle's Avatar
Always cover your rear brake, remember your life savers and make it obvious that your using your mirrors ie plenty of head movement.
But the most important thing is to relax and enjoy it. Best of luck, I'm sure you will pi$$ it.
Matt
"If Carlsberg made ginger bloke's............................. "
Treacle is offline   Reply With Quote
Old 24-08-10, 09:26 PM   #9
relax and do your lifesavers
Old 24-08-10, 09:33 PM   #10
Richi3
good luck m8 gonna be in ur position in 3 weeks time
Anyone a bit nervous ? stewie 2008 Annual Rideout 121 03-07-08 06:55 PM
OK, really nervous now. K Idle Banter 31 04-10-07 09:46 AM
Getting nervous now. stuartyboy SV Ecosse 20 29-06-06 01:40 PM
Nervous. Cronos SV Ecosse 8 14-05-06 10:38 AM
i got all nervous then! keithd Idle Banter 6 08-03-06 01:04 PM
