Old 25-08-10, 09:17 AM   #1
bengrrr
Default Adjusting rear preload - GSXR100 shock.
Hi all.
Does anybody know what the total travel on a 03' GSXR 1000 shock is as written in the manual?
Spank you all.
Old 25-08-10, 10:59 AM   #2
bengrrr
Default Re: GSXR 1000 Travel.
Right found a manual...Some may find this link helpfull?
http://wotid.com/gsxr/content/view/22/43/
SO it says...
Front fork stroke 120mm (4.7in)
Rear Wheel Travel 130mm (5.1in)
Obvious question but I take it that's what I'm after for the rear shock travel. 5.1 inches?
Old 25-08-10, 11:02 AM   #3
GrahamB
I think the shock travel (ie travel at the shaft of the shock) is 65mm. 130mm is at the axle.
Old 25-08-10, 11:47 AM   #4
bengrrr
Right but when measuring to set my sag based on my weight, 130mm 5.1in is what ill need to take into account?
or 65mm?
Old 25-08-10, 12:07 PM   #5
No, nothing like that.
65mm is absolute between top out and bottom out in shock.
All you care about is relative movement between swingarm and tailpiece (or arbitrary point).
To measure;
Unload suspension (abba stand, push bike over on sidestand, whatever... fully top out the suspension)
Measure between an arbitrary point (bit of tape on tail plastics) and point on swingarm near axle end.
This is measurement A
Then get bike on it's wheels, just supporting it's of weight.
Measure again to same point. Difference between this and A is the BIKE sag.
Get on the bike, measure again.
Difference between this and A is total or rider sag.
Old 25-08-10, 12:07 PM   #6
GrahamB
Ah, you're trying to use some rule-of-thumb formula for setting sag?
Just set it somewhere around 25-30mm rear, 35-40mm front (with you on the bike) to start with. There is no magic formula, you'lll need to fiddle with it to find what works for you and your bike where you ride.
Old 25-08-10, 12:51 PM   #7
bengrrr
Cool thanks guys. Top out doesn't mean taking the spring to its maximum setting or zero pre load. Forgive me if my terminology is misunderstood. But just making sure there is no free movment when raising the rear tail up? is that right? Then you set your sag.
Old 25-08-10, 12:55 PM   #8
Top out is when the piston inside shock is against the top out bumper... i.e when the length of the shock is at its max possible.
This can happen when you lift the tail of the bike in the air... or it can happen if you wind the preload up so high that the bike is still "topped out" even with its own weight on it.
Old 25-08-10, 12:55 PM   #9
GrahamB
It's the furthest you can move the tail from the axle, without changing any settings, as though you were lifting the bike in the air by its subframe. I think that's what you mean by "no free movement"?
Old 25-08-10, 12:58 PM   #10
bengrrr
Yeah that's what mean. Brilliant perhaps now i can get the settings right
Thanks all.
ZX10R shock preload adjustment, c spanner? Elltg Bikes - Talk & Issues 8 26-02-10 05:56 PM
Changing the Rear Suspension (adjusting standard shock) Larry SV Talk, Tuning & Tweaking 18 31-08-09 01:23 PM
Adjusting a Curvy Hagon Rear Shock TheStudent SV Talk, Tuning & Tweaking 7 22-06-09 08:44 AM
adjusting Hagon rear shock on bike.....? etuna SV Talk, Tuning & Tweaking 7 21-03-09 08:32 PM
GSXR1000 shock adjusting streetos SV Talk, Tuning & Tweaking 0 17-04-05 08:31 PM
