Old 26-08-10, 09:16 AM   #1
Berlin
Default Best way of removing spray paint from a fairing?
As Above, whats the best way of removing spray paint from a fairing?
I've chosen the new scheme for the bucket and need to get the poxy red stuff off and back to white.
Please tell me it isn't a week with the wet and dry!
If it helps its Halfrauds rattle can paint and the gel coat on the fairing is so thin its see through so I have to be careful!
Cheers,
C
Old 26-08-10, 09:49 AM   #2
keith_d
keith_d's Avatar
Default Re: Best way of removing spray paint from a fairing?
Providing the existing paint is adhering well, prep it up and spray over the top. White over red might benefit from a coat of white primer.
Old 26-08-10, 09:57 AM   #3
Dicky Ticker
You should use a plastic primer,not just normal primer, before finish coats for a 100% finish if you take it back to bare plastic.
If this is for the track bike just key it up and use a coloured base primer suitable for the finished colour and lacquer
Old 26-08-10, 11:41 AM   #4
timwilky
timwilky's Avatar
D-A sander, avoid nitromors etc. As DT says, back to the plastic and a plastic primer
Not Grumpy, opinionated.
Old 26-08-10, 11:49 AM   #5
Berlin
The adhesion of the paint is half the problem. There isn't any
Some is peeling off from whatever releasing agent was used for the manufacture of the fairing. Some is OK. I want to take it back to white and use the original gel coat as the white background for the new scheme, leaving it exposed as the white sections. (can't chip off then. You can't belive how many stone chips you get on a track!)
I'm going to try using packing case tape to pull as much off as possible I think. Then just attack the rest with wet and dry.
C
Old 26-08-10, 11:55 AM   #6
martin15s
had a similar problem a while ago on another bike - sand, wet and dry back to base - clean and degrease with tack cloth and then plastic primer etc.
Old 26-08-10, 12:16 PM   #7
Dicky Ticker
Stone chips on the track are normally associated with riding into the gravel traps and toppling over
Old 26-08-10, 12:24 PM   #8
Dicky Ticker
If the current paint is peeling off I would thoroughly recommend a quick key back to plastic and plastic primer
I believe you want dual colour so instead of using the white plastic of the fairing spray both and use coach liner tape between the colours where the colours meet.
Doing this should you incur "Gravel rash" as is prone to happen it is easy to bodge up again like new
Old 26-08-10, 10:00 PM   #9
In that case mate, polisher with a course cutting compound, fetch that right off in no time, then a fine polish and it will look sweeeeet.
Old 26-08-10, 10:12 PM   #10
Lozzo
9" angle grinder
Best place for spray paint touch107fm Bikes - Talk & Issues 12 25-06-08 04:55 PM
Fairing spray paint Zombie Jesus Bikes - Talk & Issues 16 23-05-08 11:35 PM
spray paint Blue_SV650S SV Talk, Tuning & Tweaking 5 17-03-06 12:44 PM
Halfords spray paint northwind SV Talk, Tuning & Tweaking 12 17-05-05 10:45 PM
