Old 29-08-10, 06:26 PM   #1
toby_smith
Default Adjusting Footpeg Assembly Position
Right,
Well I'm planning on adjusting the position of my footpeg assembly with the magical adjuster plates matt yokes is planning on making.
I believe there is plenty of play in the brake gubbins to move them back without an issue, but, is any extra work needed on the other side?
IE, can the gear change linkage (or whatever it's called) be adjusted to accomodate for the footpeg assembly being positioned further back?
Cheers,
Toby
Old 29-08-10, 06:39 PM   #2
Default Re: Adjusting Footpeg Assembly Position
Only if the distance that the footrest is moved is very slight, if it moves very far the gearchange rod will need to be altered.
Do not be attempted to use a rod the wrong length and turn the gearchange round on the shaft - the gearchange will be horrid. Always keep the angle between them as close to 90º as possible.
Old 31-08-10, 09:01 AM   #3
johnnyrod
johnnyrod's Avatar
Also I ended up using a hydraulic brake light switch on the rear as the plate (not Matt's) fould the switch I think, was a long time ago now. You can get them from Goodridge etc. anyway, banjo with switch built in.
Adjusting footrest position? dsb79 SV Talk, Tuning & Tweaking 6 22-08-10 09:46 PM
Clock assembly help Flameboy Bikes - Talk & Issues 19 28-11-09 05:43 PM
Raised bars for SV650S K3 wanted, also Footpeg assembly? Tallguy Stuff Wanted 0 29-09-09 11:45 AM
Is it not possible to get the gear shifter off the footpeg assembly? Jase22 SV Talk, Tuning & Tweaking 3 17-08-08 06:15 PM
k5 pointy left footpeg, gear changer assembly and left front indicator - will pay good money Paul the 6th Stuff Wanted 2 21-04-08 09:03 AM
