Old 01-09-10, 04:43 PM   #1
Ceebl
Question Unidentified oil leak.
My sv650 sk1 has developed an oil leak, its mostly noticeable when the bike is parked as it leaves a spot on the ground, defo used oil n not coolant etc.
I am aware that the k1's suffered from the plastic clutch housing and I was wondering does anyone have any tips or recommendations to prove it is this and is there any other common faults i should know about with the oil system. Also if it is a warped clutch cover is it swappable with an x or a k2 etc if they had metal clutch covers?
I am aware of the flaw but dont know much abt it. any specific help regarding the sk1 would be greatly appreciated!
Thanks org!!!
Old 01-09-10, 04:53 PM   #2
dill89
Default Re: Oil Leak
Ive no idea obviously, but I blame the gumtree ad, she knows she's gona go and wants to stay
Old 01-09-10, 04:54 PM   #3
Clean the engine thoroughly then go for a run - this should make it clear where the oil is coming from.
All Curvy clutch cases are the same.
Old 01-09-10, 05:04 PM   #4
Ceebl
I suspected as much, the leak arrived the morning after I contacted a guy about a cbf125 for commuting purposes... poor Suzie, i do love her haha
Old 01-09-10, 05:07 PM   #5
Ceebl
I might do this although iv just inspected it closely as its done about 40 miles since last gd clean and i suspect it myt be my recent oil filter... hmm more cleaning and runnin needed i fink! Lets see...
Old 01-09-10, 05:14 PM   #6
Ceebl
Default Re: Unidentified oil leak.
when you get a new oil filter for servicing dont you get a replacement o-ring for the joint? I may have located the cause of the leak, il keep posting when I find out.
Old 01-09-10, 05:15 PM   #7
Ceebl
disregard the start of my last, I def got a new o-ring as warrenhewitt10 remembers fitting it himself haha
Old 01-09-10, 06:07 PM   #8
Ceebl
I believe I have solved the problem, oil appeared to be pooling at the bottom of the filter so I put a rag round it n had a swing n sure enough it gave a wee crack n I got about another 1.5 turns on it (hand tight) so i then put a white rag under it and let it heat up and run on idle for about 5 min, reved it a bit, let it idle some more and turned it off... its been cooling for about 10 minutes now and so far no oil spots, might get to test it tonight, if not I will post after work tomro and let everyone know the verdict! thank god its not the clutch cover anyway, this could be a much easier job touch wood, but heres hoping!!!
Oil leak :-( 7755matt SV Talk, Tuning & Tweaking 14 16-09-09 05:35 PM
Unidentified wire yorkie_chris SV Talk, Tuning & Tweaking 6 15-09-07 08:46 PM
Oil Leak glade SV Talk, Tuning & Tweaking 15 08-06-06 09:39 AM
Gas leak! imaleon Bikes - Talk & Issues 10 06-05-06 03:23 PM
Not oil leak - Petrol leak - double "Bugger"...! Potts SV Talk, Tuning & Tweaking 1 17-10-04 08:16 PM
