Old 02-09-10, 01:10 PM   #1
collis
Default Exhaust blowing from the link pipe
Hi All,
I've only had my blue curvey for 2 weeks but i've noticed 1 minor annoyance,
at the point where the 2 downpipes from the cylinders meet then join to the exhaust i've noticed that it is blowing a little around the clamp.
My question is, if i loosened the clapm and the bolt holding the can on could i easily pust it a little further on and then tighten the clamp again or could you recomend a better way to fix it?
I've also noticed some soot around the area that it is blowing, is that something i need to worry about or could it be simply what's left from the bike being un-used for a year?
ie crap sitting in the carbs etc.
Old 02-09-10, 01:25 PM   #2
RichT
Default Re: Exhaust blowing from the link pipe
Try the clamp otherwise Halfrauds > Fire Gum if it's worrying you that much.
You'll probably find it'll coke up (sooty bit) and stop blowing itself after a while.
Old 02-09-10, 01:39 PM   #3
cuffy
Silicone sealant also works, usually cheaper too
Old 02-09-10, 01:59 PM   #4
collis
But that would mean i't need to stop cleaning it, something that wont happen.
I'll certainly give one of the sealents a try, eventually i'll probably just buy a new can but untill the budget allows i'm sticking witht he stock one.
Old 03-09-10, 11:23 AM   #5
dill89
yea if you loosen the clamp then you could try pushing the end can further on, maybe take it completely off first so it's loose enough then slip it on as far as you can, then give the clamp a good tighten.
not too sure, but i donl't think there's any reason to worry about the sootyness
Old 03-09-10, 12:27 PM   #6
Spiderman
Where the hell am I?
Spiderman's Avatar
Dont waste your time with this stuff. It just doesnt work on an SV i found. Its dries out too quick and ends up just falling out like old grout from between tiles.
This stuff on the other hand always stays flexible and you really dont need the super duper stuff they tout as "made for motorbikes" on some websites. I use B&Q's own budget sealant. Cost about a fiver for a tube. Just make sure you get the one that dries clear or it looks a bit crap.
Exhaust Link Pipe sv_rory For Sale - SV's and SV related items 11 28-01-11 05:02 PM
ART GSXR exhaust link pipe. Iceman Bikes - Talk & Issues 4 13-04-10 06:03 PM
Exhaust link pipe Barney Stuff Wanted 1 16-06-09 03:49 PM
where can I get an exhaust link pipe? help !! muddycoffee SV Talk, Tuning & Tweaking 4 12-10-06 01:34 PM
Exhaust link pipe mac SV Talk, Tuning & Tweaking 1 11-07-05 07:10 PM
