Old 06-09-10, 09:23 AM   #1
bigchris
Default naked brake reservoir screws
does anybody know what size these are? my original posidrive ones have started to round off!!!!
im sure i can get them out but need new replacements to go back in.
im going to get some from a nuts and bolts supplier but i need the size ( thread size length and pitch )
brake fluid needs topping up you see,
can anyone help?
cheers,
Old 06-09-10, 09:27 AM   #2
Take one out when you get to the shop. I just got mine from Suzuki
Old 07-09-10, 06:16 AM   #3
Spanner Man
Default Re: naked brake reservoir screws
Good morning all.
M4 x .7mm. 12mm long should do methinks.
Make sure you put a little 'coppperslip' on the threads, & on the countersunk part of the head of the new screws. This should help prevent them seizing.
If your brake fluid needs topping up, check your pads. They may be worn. This would cause the fluid level to drop.
Cheers.
P.S. The standard screws have a Phillips head, & not Pozi-Drive
Spanner Man
Front brake reservoir K3 S Stingo Stuff Wanted 1 14-08-10 01:22 PM
Front brake reservoir screws DANINPLYMOUTH SV Talk, Tuning & Tweaking 10 28-05-09 06:54 AM
Brake Fluid reservoir for 99-08 Naked askin'45 maxxdope For Sale - SV's and SV related items 6 03-04-09 03:22 PM
Front brake reservoir for naked curvy. Stig Stuff Wanted 3 22-09-06 04:23 PM
brake reservoir cap toffo Stuff Wanted 0 27-07-06 03:48 PM
