Old 08-09-10, 06:44 PM   #1
stevierhodes
Default Brass choke slider thingy
I need the brass end piece that goes into the carb after the spring on the carb end of the choke cable that looks like an RCA phono plug made of brass. Its for a 1999 SV650 Carb model. I rang Suzuki and they do not seem to sell them. Has anyone got a part number for this item or knows how to obtain one. Many thanks Steve the newbie to this forum and bike.
Old 08-09-10, 06:46 PM   #2
Default Re: Brass choke slider thingy
Try these guys. Good service
http://www.nrp-carbs.co.uk/
Old 08-09-10, 07:42 PM   #3
stevierhodes
Thank you will do found out from another forum member that its a valve starter/plunger starter part number 13411-01400.
Could we start a brass band? ooger Idle Banter 16 21-09-09 07:49 PM
brass springs Wideboy Idle Banter 9 28-07-09 05:40 PM
Frame Slider Bolts rick0361 SV Talk, Tuning & Tweaking 0 26-03-08 10:26 PM
Brass Monkey Run, Jan 1st Lissa The Madlanders 13 01-01-08 08:38 PM
2nd January 2005 BRASS MONKEY RUN. Moo The Madlanders 22 06-01-05 06:35 PM
