Old 12-09-10, 03:34 PM   #1
Wideboy
Evel Knievel
Wideboy's Avatar
Default front cylinder misfire
front cylinder keeps konking out and is getting progressively worse, gets more violent as bike comes up to "normal" temperature but over the last three rides it has got really bad.
checked it all over, got a healthy spark and everything works as its should but when out and about with the bike up to temperature the front cylinder starts cutting out with the loss of the rev tacho (so its and electrical problem? ). starts off as just sounding a little rough and when revs increased it goes, but after a while the cylinder cuts completely and you had to dip the clutch and give it an aggressive fist full to get it to kick back in. Tuesday night i did 35 miles on the motorway with a constant 7k revs for the whole 35 miles (late and road was clear) without fault but as soon as i came down the slip road and rolled off the throttle it started.
i cant see anyhting wrong so im thinking something electrical is brokeded, coil for the front perhaps??
p.s. no its not water in the front plug and yes i have changed the plugs
05 DRZ400E
RIP hovis
Old 12-09-10, 03:56 PM   #2
widepants
widepants's Avatar
Default Re: front cylinder misfire
gav..are u 100 percent sure its the front one,or is that another daft?
widepants is offline   Reply With Quote
Old 12-09-10, 04:13 PM   #3
Fuel blockage?
The fact that a fistful stops it suggests fueling to me ???
Old 12-09-10, 04:15 PM   #4
Wideboy
Evel Knievel
Wideboy's Avatar
well i burnt my finger on teh rear downpipe trying to find out so i'd say im 100% lol
Fuel blockage?
fuel blockage would be constant problem tho not intermittent? also i wouldnt have thought you would loose the rev tacho? i duno im crap with electrics
05 DRZ400E
RIP hovis
Old 12-09-10, 04:18 PM   #5
Exactly whats happening with the tacho when you lose the one cylinder ?
Old 12-09-10, 04:19 PM   #6
Wideboy
Evel Knievel
Wideboy's Avatar
it goes straight to zero, not a slow gradient as the revs drop, just drops straight away to zero
05 DRZ400E
RIP hovis
Old 12-09-10, 04:26 PM   #7
fizzwheel
fizzwheel's Avatar
Tacho IIRC takes its feed from the coil that runs one of the cylinders, I cant remember which one though. Sounds electrical to me, but I'm no expert where this is concerned.
Liz's SV is doing something similar, tried new plugs etc etc. Bought a 2nd hand coil off ebay in the end but never got around to fitting it, but thats where I'd start in your shoes.
Old 12-09-10, 04:27 PM   #8
Wideboy
Evel Knievel
Wideboy's Avatar
im pretty sure it runs off the front coil so unless theres a didgy connection id say it was fubard
05 DRZ400E
RIP hovis
Old 12-09-10, 04:30 PM   #9
It does sound like the coil mate, if the tacho is going to zero, each cyclinder has its own coil doesnt it?
Swap it over with the rear cycliner see if porblem transfers to the that one.
Old 12-09-10, 04:34 PM   #10
Wideboy
Evel Knievel
Wideboy's Avatar
aren't front and rears different?
05 DRZ400E
RIP hovis
Misfire and strange front brake problem Sooty SV Talk, Tuning & Tweaking 5 09-03-10 06:16 PM
Front cylinder not firing - why? trinyquist Bikes - Talk & Issues 9 17-12-07 07:56 AM
Front master cylinder taggy Stuff Wanted 7 31-08-07 06:02 PM
K4 Front Cylinder Head Sideshow#36 Stuff Wanted 2 13-08-07 08:12 PM
R1/R6 Front master Cylinder jonnygman SV Talk, Tuning & Tweaking 6 29-04-07 01:10 PM
