Old 13-09-10, 10:17 AM   #1
tom-k6
Default Jumping out of 2nd back to neutral.
if im giving it the beans in first, change the 2nd, as soon as i start revving it past about 6000rpm, it will jump back to neutral
just wondered if its something the bike is doing or something that i am not doing right??
anyone else have this??
Old 13-09-10, 10:33 AM   #2
warrenhewitt10
Default Re: jumping out of 2nd back to neutral..
just make sure you lift the lever up the whole way, this is hard to do at speed, i find second gear to be the most clunky on my bike
Old 13-09-10, 10:39 AM   #3
Make sure you're not shifting like a fanny, and that you're doing the right thing with the revs. If you've still got the throttle on and trying to shift it might not engage all the way.
Make sure you are deliberate with the lever and move it right up to the top of it's travel. Second is a longer throw than others.
Assuming you can actually ride a bike, how many miles on the bike? Has it ever been raced? These gearboxes are quite strong generally. But dogs and forks can wear if given sufficient abuse.
Old 13-09-10, 11:09 AM   #4
tom-k6
i got the bike at 5300 miles last november and now has almost 14000 so done a fair few this year, its probably just the longer travel of the shift, i'll nip out today and see what i can do differently,
thanks for advice guys,
Old 13-09-10, 12:02 PM   #5
Also check the lever is free and not binding, but this is less likely to cause this problem.
Old 13-09-10, 01:49 PM   #6
breakz187
its a binding lever - you have to lube/cleaner the contact surfaces between the lever and the peg. get some wd40 in there and then some oil or spray silicone grease. I've had this before, twice - both after the winter.
breakz187 is offline   Reply With Quote
Old 14-09-10, 11:07 PM   #7
lol omg wtf
Default Re: Jumping out of 2nd back to neutral.
don't know if its the same problem but my bike started dropping out of second a few weeks ago, I had the clutch lever set stupidly responsive, as soon as I released it a fraction it was off sort of thing... don't know why, but hey that's how it was set.
anyway after I adjusted it to something more reasonable it solved the problem of the bike falling out of second.
Old 15-09-10, 11:41 AM   #8
breakz187
when i said lever, i actually meant the the foot lever for the gear box.
Old 15-09-10, 11:48 AM   #9
DaveW_42
DaveW_42's Avatar
I used to have this too - for me it was just a case of being more positive with the gear change. Seems to be quite a common thing with the SV. As YC says, it's a longer travel than the rest of the gear box so really bang it in.
K4 trackbike, a black K8 S loaded with my spares and a 1989 CBR 400 TriArm with all the trimmings.
DaveW_42 is offline   Reply With Quote
Old 15-09-10, 11:56 AM   #10
You don't have to be viscious, just make sure you move your foot up all the way
Jumping speedo Mads_DK SV Talk, Tuning & Tweaking 6 11-07-10 09:43 AM
jumping out of gear AndyBrad SV Talk, Tuning & Tweaking 15 12-05-09 09:47 PM
Bike keeps jumping out of 2nd gear. jimmy-james Bikes - Talk & Issues 23 25-04-09 11:13 PM
jumping out of 2nd :-( The Laughing Assassin SV Talk, Tuning & Tweaking 10 24-06-08 12:27 PM
Cliff jumping! ClemsonSV Idle Banter 7 25-07-07 02:23 PM
