Old 20-09-10, 09:49 PM   #1
barwel1992
Default Which drive chain is best?
what would you lot say is best ?
Tsubaki Alpha 'X' Ring Drive Chain - 525 Pitch - 110 Links
Renthal R4 SRS 525 Pitch Drive Chain - 110 links
will be run with a renthal front sprocket and a Supersprox stealth rear sprocket (steel teath)
Old 21-09-10, 05:52 AM   #2
Spanner Man
Default Re: Drive chain ?
Good morning.
I like the hyper bollix waffle in the ad for Renthal chains. X ring or O ring makes little difference if you keep it lubricated correctly.
I've never seen a Renthal chain do excessive mileage. The Tsubaki Alpha chain is their second grade down. You might as well pay the extra & get their SG grade chain this is their premium grade with O rings. For a little more get their SGX grade. This is an SG chain with X rings & a PGF. (Poncy Gold Finish).
Cheers.
Spanner Man
Old 21-09-10, 04:27 PM   #3
barwel1992
cheers for that
Change chain for Belt drive capitanscott SV Talk, Tuning & Tweaking 10 26-11-09 06:18 PM
Morax Gold Chain Wax / Wurth Chain Wax glade Ancillaries 3 14-02-08 06:41 PM
Drive chain tensioner Stingo SV Talk, Tuning & Tweaking 1 16-08-07 09:52 PM
New drive chain fitted, now theres an odd noise... triumph5ta SV Talk, Tuning & Tweaking 6 27-03-06 12:19 PM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
