Old 21-09-10, 08:33 AM   #1
slloyd
Default Coolant Leak
Good Morning Folks,
This morning got to work and once I parked the bike up, coolant started leaking from the pipe circled in the picture. Can anyone hazzard a guess as to why this has happened?
I recently serviced the bike, but all has been fine for over a week now, so unsure as to why this has just happend.
Thanks in advance.
Old 21-09-10, 09:20 AM   #2
martin15s
Default Re: Coolant Leak
if you had just serviced it you probably had air left in the system - looks as though the air has escaped through the overflow - have you checked the coolant level since?
Old 21-09-10, 11:39 AM   #3
slloyd
Just tried to have a gander at the coolant levels, but can't see if the level is ok or not due to the discoloration of the container. I have spoke to a local bike shop about it, and wondered if worst case all the coolant had leaked out - would I be about to drive the bike 5 minutes literally around the corner to drop it off.
Old 21-09-10, 11:42 AM   #4
husky03
matey give the lower hose on the rh side a couple of squeezes , you should be able to feel/hear the coolant swishing about
Old 21-09-10, 11:58 AM   #5
slloyd
Hi Husky, I cannot hear/feel the coolant swishing about, so does that means it's totally empty and not rideable for about 500mtrs.
Old 21-09-10, 12:16 PM   #6
husky03
fill up the rad with water and then ride it the short distance should be ok mate
Old 21-09-10, 12:28 PM   #7
slloyd
Just got back from the local mechanic...and he checked the bike over and saw that it was just filled up too much.
No other tell tale signs of leaking elsewhere, so that's a little relief - All he said was to keep an eye just to make sure it isn't leaking from anywhere around the engine.
Thanks for your replies.
Old 21-09-10, 09:26 PM   #8
That pipe is the overflow from the coolant header tank, (and the filler well drain), if the system is overfilled that's where the excess will emerge from - as you've recently learned.
Old 21-09-10, 09:49 PM   #9
Yup just overfilled, nothing to worry about, don't do it again cos coolant is slippy.
Old 21-09-10, 10:30 PM   #10
as YC and it is!
Radiator / coolant leak El Saxo SV Talk, Tuning & Tweaking 4 23-07-10 04:38 PM
coolant leak SimJ SV Talk, Tuning & Tweaking 0 02-05-07 11:05 PM
Speedo Rotor & Engine coolant leak Nitzer SV Talk, Tuning & Tweaking 2 02-01-07 09:20 PM
Coolant leak LHS Tex SV Talk, Tuning & Tweaking 0 13-05-05 01:51 AM
Not oil leak - Petrol leak - double "Bugger"...! Potts SV Talk, Tuning & Tweaking 1 17-10-04 08:16 PM
