Old 22-09-10, 04:36 PM   #1
Girth
Default Riders footrest/brake pedal
Hey,
Cleaned up my rear caliper, thought I'd clean up the brake pedal pivot. Stripped the foot peg out, cleaned up and gone to put it all back together as I thought it was. The bloody brake pedal has gone tight, double checked and check again on how it was assembled and I've drawn a blank.
There is a washer that sits on top of the foot peg (or at least i think) that is present but as soon as I tighten the bolt up into the footpeg the brake pedal goes tight. Without the washer the brake pedal floats about on the foot peg.....
Help
Old 22-09-10, 08:03 PM   #2
simesb
Default Re: Riders footrest/brake pedal
Have you looked at the fiche to see how it was originally assembled?
Old 22-09-10, 08:17 PM   #3
girth this the fitche drawing
http://fiche.ronayers.com/Index.cfm/...K4/K5/K6/K7)_#
Old 28-09-10, 01:15 PM   #4
Girth
Yep checked the fische and shows no washer.....
Puzzled. I've left it off, it'll be reet.........
Old 28-09-10, 08:41 PM   #5
garynortheast
garynortheast's Avatar
Washer should be behind the brake pedal.
Old 28-09-10, 08:45 PM   #6
Cymraeg_Atodeg
If it is too tight with the washer take it out and just apply enough copper grease to keep out the water and keep the pedal moving.
When I put my assembly back together I thought it had two washers and wouldn't budge, but, it only has a very thin on between the foot-plate assembly and the brake pedal. The peg and pedal should be touching (but, apply copper grease here too)
Old 29-09-10, 05:20 PM   #7
I wouldn't use copper grease - it's not a good lubricant and too grainy for the fibre bush, ordinary multi purpose would be better.
Copper grease is a bit of a misnomer - it's an anti seize compound rather than a lubricant.
Old 29-09-10, 07:17 PM   #8
Cymraeg_Atodeg
Well, my pedal hasn't seized yet
k1 brake pedal bigchris Stuff Wanted 2 10-08-10 11:15 AM
Curvy brake lever & rear brake pedal Old Git Stuff Wanted 1 09-01-10 11:00 AM
Riders L/H Footrest Mount richard7510 Stuff Wanted 9 18-05-08 10:17 AM
SV650 R/H footrest peg brake pedal full assembly mgilbe For Sale - SV's and SV related items 1 23-01-08 10:58 AM
Clutch lever, brake pedal and left riders footpeg k5 naked Bear Stuff Wanted 0 05-08-07 09:13 PM
