Old 29-09-10, 09:39 PM   #1
gabrielkeown
Default Gear change indicator - any advice?
Hi folks was thinging of putting a gear change indecater on my sv650s k2 any 1 got some advice
thanks
Gaby
Old 29-09-10, 10:55 PM   #2
Default Re: Gear change indicator - any advice?
Yeah don't bother.
Old 29-09-10, 10:58 PM   #3
simesb
Gear indicators are NOT the anti-Christ. Fit one if you want it ( you don't need one, but it's your bike)
Old 29-09-10, 11:06 PM   #4
rictus01
rictus01's Avatar
do you mean a gear indicator or a shift light ? you don't need either, but I think that's besides the point, the datatool "revlight" is a programable set of led's to indicate revs or shift levels, or the "digi" gives a number for the actual gear you're in, both need programing, but that's easy to do.
A number of other companies do the same sort of thing as the Digi, so look around.
Cheers Mark.
Old 30-09-10, 08:49 AM   #5
punyXpress
punyXpress's Avatar
Yep - when they're dirty, change them.
Now: Street Triple R
Old 30-09-10, 10:21 AM   #6
SoulKiss
SoulKiss's Avatar
Learn to count...
Old 30-09-10, 11:50 AM   #7
toby_smith
If you need to change up, change up, if you need to change down, change down.
If your pedal won't go any further up, you're in 6th, if it won't go any further down you're in 1st.
If you need to change down and the pedal won't go down any further, you're going far too slow.
If the little green light on your dash is on you're in neutral.
Remember those four points and a gear indicator will no longer be needed
Old 30-09-10, 11:51 AM   #8
Stephen McG
I would probably never fit one to a bike, but my Gladius has one as standard.
It is useful when commuting in heavy as you can see what gear you are in (obvious)
My previous 3 bikes only had 5 gears so at first I was out of habit to go to 6.
Aftermarket ones probably work on roadspeed/rev rations, however the Gladius will register gear if bike stationary.
My next bike may not have one but I will enjoy the novelty for the moment.
Stephen McG in Glasgow
Old 30-09-10, 11:52 AM   #9
Stephen McG
Yes - it should say ratios (not rations)
Old 30-09-10, 11:57 AM   #10
simesb
Learn to count...
Counting isn't the problem - it's remembering.
I really don't understand why people have such a problem with them. I understand you don't need one, but they are a handy reminder. They will not make sure you are in the right gear, or stop SMIDSY but people like them which is why more and more bikes have them fitted as standard.
Gear change problem-can't get past 2nd gear muzikill SV Talk, Tuning & Tweaking 8 14-03-10 10:10 PM
Gear change problem-can't get past 2nd gear muzikill SV Ecosse 8 13-09-07 07:45 PM
DIY Gear Indicator. Chinaman SV Talk, Tuning & Tweaking 16 14-12-04 10:18 AM
