Old 05-10-10, 08:13 PM   #1
newts924
Default Clutch Problem.
Some dic# at work moved my bike today and when i came to ride it the clutch lever was very hard to pull in and was hard to engage a gear.
My bike had the steering lock on so they must of dragged it to move it.
Anyone any ideas what it could be.
Old 05-10-10, 08:26 PM   #2
TamSV
TamSV's Avatar
Default Re: Clutch Problem.
Cable adjustment? They've maybe pulled at the cable when dragging the bike.
You need to have a quiet word.
Old 05-10-10, 08:43 PM   #3
Preferably with a item of bike security and gaffa tape
Old 05-10-10, 11:05 PM   #4
I take it there's no obvious, outward reason thats causing the lever to be restricted?
If no, then remove the cable and see if the lever moves freely without it, hopefully this will identify the cause of the problem
Old 05-10-10, 11:22 PM   #5
having a think about it.
Was it left in gear when you parked/ moved without consent?
I would check the adjuster that is in (i think) front sprocket cover if it doesn't loosen up
Old 06-10-10, 02:18 AM   #6
davepreston
give me a shout when your free and i'll give it a look over
Old 06-10-10, 08:15 AM   #7
warrenhewitt10
i would loose the rag if someone so much as touched my bike when it was parked somewhere nevermind drag it somewhere
Old 06-10-10, 08:39 AM   #8
collis
You ought to buy one of these and introduce it to the nice persons back:
Alternatively:
leave one of them in your bag... when you take the cat out of the bag you gotta use it on somebody
Old 06-10-10, 07:25 PM   #9
They may have heaved on the lever and bent it slightly causing difficulty in moving it. Do as Sid says.
Old 07-10-10, 09:54 AM   #10
hongman
And when you find out what is damaged (if anything) make sure they pay fot fixing it...some people, honestly.
Clutch Problem? DEJA_Vu SV Talk, Tuning & Tweaking 9 18-02-09 08:33 PM
Clutch problem samusamus SV Talk, Tuning & Tweaking 2 20-01-08 08:59 PM
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
My clutch problem TSM SV Talk, Tuning & Tweaking 21 08-09-05 08:42 PM
Clutch Problem Slim SV Talk, Tuning & Tweaking 8 12-10-04 06:25 AM
